valentinas
HAP AC2 reset problem
Tue Mar 28, 2023 11:18 am
I have HAP AC2, reset it via reset button (turned off, while turned off press and hold reset button), power up, usr led blinks several time, reset button release.
connected LAN 1st port to LAN of computer, and as I understand it should give DHCP address to laptop, but it don't do it, Mikrotik LAN port is blinking.
please guide me, what i`m doing wrong.
BR,
Val
Ca6ko
Long time Member
Long time Member
Re: HAP AC2 reset problem
Tue Mar 28, 2023 1:11 pm
connected LAN 2-5 port to LAN of computer,
1st port to WAN, default config.
valentinas
Wed Mar 29, 2023 8:56 am
yes i`m connected to first LAN port, I have in mind that WAN port will not work
erlinden
Wed Mar 29, 2023 9:06 am
Connect computer to second LAN port (or third, fourth and fifth).
Can you please explain what the problem is?
BrateloSlava
Wed Mar 29, 2023 9:19 am
Did you decide to reset because the router stopped booting normally? That is, after turning on the power, did the router blink its lights and reboot itself?
Ca6ko
Long time Member
Long time Member
Wed Mar 29, 2023 9:47 am
This only works when the laptop is connected to ports 2-5.(LAN) Port 1 is configured to connect to ISP equipment.(WAN) This is the default configuration.
So what's not working for you?
Users browsing this forum: Google [Bot] and 71 guests
