luisrs01
LAG not all interfaces work
Tue Mar 28, 2023 3:54 pm
Greetings
I have the following problem
I have three wireless links
at each end I have swos and I use lag to be able to add the links
the problem is that only one interface receives and transmits and the other two only transmits
I attach an image of the LAG configuration and the network diagram between my provider and my Core, which is a CCR2116
Thank you so much
tdw
Re: LAG not all interfaces work
Wed Mar 29, 2023 7:16 pm
Likely working as designed, see https://help.mikrotik.com/docs/display/ ... -Problem.2. You cannot change the transmit hash policy in SwOS, from the manual CSS610 "load balancing based only on Layer2 hashing" and CRS318 "load balancing based on Layer2, Layer3 and Layer4".
luisrs01
Fri Mar 31, 2023 3:03 am
What could be the implementation that I would be needing so that I could do the job correctly?
tdw
Re: LAG not all interfaces work  [SOLVED]
Fri Mar 31, 2023 9:39 pm
Replacing the CSS device with one which supports other hashing methods may help - it depends on the source and destination MAC, IP, TCP/UDP ports of the traffic in question, and how they vary for the traffic streams.
Users browsing this forum: No registered users and 13 guests
