BigCol
Advice please CRS125-24G-1S-2HnD-IN or CRS326-24G-2S+IN
Tue Mar 28, 2023 4:10 pm
Hey guys, i need some advice please.
I have a need for a switch with 16 ports, this may grow in the future.
I already have a couple of the CAP XL APs that are working very well across the property and these are connected to a Draytek Router with internet connection
My plan is to replace the old Draytek 2860 and a couple of unmanaged switches that seem to cause too many issues with broadcast storms.
I was about to order the CRS326-24G-2S+IN and then noticed the CRS125-24G-1S-2HnD-IN.
has a USB port - could be useful
has wifi - not required
has slower processor
I'm wondering if the CRS125-24G-1S-2HnD-IN has any other reason that makes it a preferred choice over CRS326-24G-2S+IN???
Many thanks
Colin
pcunite
Re: Advice please CRS125-24G-1S-2HnD-IN or CRS326-24G-2S+IN
Tue Mar 28, 2023 4:42 pm
If you want to learn the old way of configuring switches, lose an SFP+ port, and have useless wifi, the CRS125 is a good buy.
BigCol
Tue Mar 28, 2023 6:09 pm
chechito
Re: Advice please CRS125-24G-1S-2HnD-IN or CRS326-24G-2S+IN  [SOLVED]
Tue Mar 28, 2023 10:29 pm
i think CRS-125 is almost EOL go for the CRS-326
Users browsing this forum: lubara and 173 guests
