BigCol
Routing problem, new setup
Tue Mar 28, 2023 11:27 pm
Hi guys, i have 2 x Cap XL AP'S, both wired directly into an internet connected Draytek router.
I has been trying to use CapsMan to configure both APs, but I found it confusing in the end and removed the config and configured them separately - all working lovely now, apart from...
When I reboot one of the APs, the other loses connectivity and i cant figure out why.
The IP addresses for each are configured using the DHCP server on the Draytek
Kitchen AP 192.168.1.201
Office AP 192.168.1.202
Any pointers as to where i might investigate please??
Colin
anav
Re: Routing problem, new setup
Wed Mar 29, 2023 4:18 am
Without the config of each CAP, should I use my crystal ball ???
Duplicate mac address??
BigCol
Wed Mar 29, 2023 7:36 pm
Is there a command i can run that will give me the config you need to see?
anav
Wed Mar 29, 2023 8:08 pm
BigCol
Wed Mar 29, 2023 10:49 pm
conf_OFFICE_29032023.rsc
conf_KITCHEN_29032023.rsc
files added :)
anav
Thu Mar 30, 2023 12:55 am
Im confused, are these both just one flat network.
All users are on the same subnet??
If there were vlans per subnet that would make sense ( for example one could have a trusted subnets with two SSIDs, 2.4 and 5ghz
and the rest different vlans for diff purposes, guest wlan 5ghz, iot 2ghz, media 2ghz etc......
BigCol
Thu Mar 30, 2023 1:30 am
The answer to your question is yes, right now one subnet, one flat network, and i have connectivity to all my devices as required, however I've been looking at this guide to implement VLANs viewtopic.php?t=143620, but i haven't started on this yet.
Right now though, when i pull the power from the Office AP, i am unable to connect to the Kitchen AP using WinBox, even though i am connected to the Kitchen AP via the Home SSID. Both AP's are directly connected to my main Draytek Internet router.
Thanks for your assistance so far
Colin
Ca6ko
Long time Member
Long time Member
Thu Mar 30, 2023 12:12 pm
I don't see any problems in the config. Except in the point of office interface with the name home5 is not included in the bridge, respectively, the devices connected to the SSID home 5 have no access..
A couple of clarifying questions.
1. How are the cables connected to the access points? Is it cascaded or is it a separate cable?
2. What are the MAC addresses on the bridge local?
3. Can't you connect through winbox by MAC or IP?
404Network
Thu Mar 30, 2023 4:53 pm
Not interested in chasing a config. When you have a plan and endstate in mind will be happy to assist in vlans....
Read C. viewtopic.php?t=182373
BigCol
Thu Mar 30, 2023 6:23 pm
I don't see any problems in the config. Except in the point of office interface with the name home5 is not included in the bridge, respectively, the devices connected to the SSID home 5 have no access.. Colin: Winbox shows Home5 included in the bridge - maybe i'll remove/re-add?
1. How are the cables connected to the access points? Is it cascaded or is it a separate cable? Colin: Each is separately cabled to the draytek router.
2. What are the MAC addresses on the bridge local? Colin: Office-18:FD:74:76:E5:CE, Kitchen-18:fd:74:76:e7:72
3. Can't you connect through winbox by MAC or IP? Colin: now i can connect....how odd.
Ca6ko
Long time Member
Long time Member
Thu Mar 30, 2023 9:03 pm
Kitchen-18:fd:74:76:e7:72 is the MAC port, you need to set an individual MAC for the bridge (Admin MAC address) otherwise bridge takes MAC of one of the interfaces
You have two interfaces with similar names home5.0 and home5 in the bridge only one
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country="united kingdom" disabled=no mode=ap-bridge name=home5.0 security-profile=home ssid=home wps-mode=disabled
add keepalive-frames=disabled mac-address=02:00:00:AA:00:03 master-interface=home5.0 multicast-buffering=disabled
name=home5 security-profile=home ssid=home5 wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add bridge=local interface=ether1
add bridge=local interface=home2.4
add bridge=local interface=home5.0
add bridge=local interface=masterh5
add bridge=local interface=sonoff
add bridge=local interface=guest
Users browsing this forum: beeman, Bing [Bot], Google [Bot], Majestic-12 [Bot] and 189 guests
