aliengen
Wireguard Mikrotik's S2S redirect all traffic
Wed Mar 29, 2023 3:13 pm
I have a small problem and I'm unable to solve it on my own.
I have 3 Mikrotik devices and I want to configure them in the following way using wireguard (right now I'm using GRE tunnel and it works just fine):
MT #1 should send all it's traffic to MT #2 (to change IP address of devices connected to MT #1). At the same time MT #1 should also be connected to MT #3 in order to access it's LAN (for remote workers to access machines via RDP). MT#2 and MT#3 are not directly connect to each other.
As of now I created Wireguard interfaces and peers. Connecting MT#1 to MT#3 in order to access machines via RDP is not a problem at all. But when I'm trying to connect MT #1 to MT#2 in order to change IP addresses of connected devices everything goes south. I didn't even manage to make MT #1 to MT #3 work (without connecting to MT #2).
If anyone could help me resolve this problem I'll be very grateful.
I'm new to this forum and this is my first post. If there is anything I missed or wrote wrong, please forgive me. I'll be happy to provide any information.
Thank you again!
anav
Re: Wireguard Mikrotik's S2S redirect all traffic
Wed Mar 29, 2023 7:12 pm
In general --> viewtopic.php?t=182373
New Poster --> viewtopic.php?p=908118
Basically a diagram speaks volumes
Config of all three devices required
/export file=anynameyouwish ( minus router serial number and any publicWANIP information )
However, you should also from the first link read PARA F
What we need to know is if the device (M1) that needs to go out INTERNET (presume on M2) but also go to subnets on M3, is the server for handshake.
If so, what you ask will not be possible on a single wg interface.
Reason being is allowed IPs for peers
if M1 to PEER M2 allowed IPs is 0.0.0.0/0 then the router will never choose
M1 to Peer M3 for subnets as the router will already have selected M1.
Now you can work around by in ORDER put M3 as the first peer in the router config
and then all requests to go to M3 subnets will go to the M3 peer
everything else will be picked up by M2 peer
Not necessarily recommended and by the way you have not noted any traffic requirements yet between M2 and M3
Users browsing this forum: JmJ17, sch and 100 guests
