benjaminkah
mikrotik sfp
Wed Mar 29, 2023 3:40 pm
mikrotik sfp
tdw
Re: IPLOAD ISSUE IN BOODING BALANCE RR
Wed Mar 29, 2023 11:06 pm
Bonding is not load balancing. I would not use balance-rr on links with variable latency, even on fixed copper and fibre links you can get out-of-order packet delivery.
benjaminkah
Mon Apr 03, 2023 5:55 am
what do you suggest to me my brother? on your side what are you using for aggregation i mean to carry more capacity which cannot be carried by a single link
tdw
Thu Apr 06, 2023 3:05 am
There is no single solution which will work, it depends on your network architecture and exactly what layer2/3/4 traffic is involved.
Users browsing this forum: No registered users and 67 guests
