sirajvlr
SNMP OID for Precision Time Protocol router os 7.8
Wed Mar 29, 2023 3:43 pm
Hi Team,
I am new to the group.
I have a query on monitoring Precision Time Protocol on the router OS version 7.8. When I run the command /system/ptp> monitor 0 I get below outputs.
gm-clock-id:
master-clock-id:
slave-port:
offset:
freq-drift:
slave-port-delay:
Can I get these output value from an SNMP monitoring server? I could not find any MIB supporting for these output.
Amm0
Re: SNMP OID for Precision Time Protocol router os 7.8
Wed Mar 29, 2023 6:38 pm
Possible they don't support the standard PTPBASE-MIB (RFC-8173), or at least not documented as such. Maybe worth a try to load that MIB and use those OID to see.
rextended
Wed Mar 29, 2023 7:05 pm
RouterOS do not support PTP on device used from the OP.
Amm0
Wed Mar 29, 2023 8:00 pm
Fair enough, now that I look...no results in the CLI isn't a good start.
But, I'm not sure they support PTPv2 via SNMP on the few high end units have it:
https://help.mikrotik.com/docs/display/ ... e+Protocol
sirajvlr
Thu Mar 30, 2023 2:06 pm
I can fetch the PTP sync data from the CLI when I put the monitor 0 command. But I want to retrieve the same data from the monitoring server so that I can check any deviation on the time synchronisation.
My device model is: CRS326-24S+2Q
I tried the PTPBASE-MIB (RFC-8173) without luck :-(
Amm0
Re: SNMP OID for Precision Time Protocol router os 7.8  [SOLVED]
Thu Mar 30, 2023 4:02 pm
I'd file a ticket at help.mikrotik.com to ask (and include supout.rif with it). It may be exposed somewhere else, or it's a reasonable feature request alternatively.
Users browsing this forum: iDaemon and 132 guests
