laurenttaieb
Dual WAN Configuration
Wed Mar 29, 2023 11:20 pm
Hello Forum,
I'm trying to set up a dual WAN configuration (FTTH + 5G upstream connections) for my home network.
I've used a great method which is available from Router OS 7.3 using reccursive routing, scope and target scope (https://www.youtube.com/watch?v=eTmpBAAW_pQ) but I still have routing issues as apparently some default configuration prevents the route setup to work. When I go into the Route List and try to remove them, RouterOS reinstall them automatically.
I'm not using fib nor masquerade firewall rules.
Can someone tell me what can be done.
I'm pinging far end DNS servers from the 2 to check connectivity from the main router and the packets look to ignore the scope and target scope setup chosing themselves the route to use.
Happy if someone can help.
Laurent
PS: I have posted the question in a wrong forum previously
anav
Re: Dual WAN Configuration
Wed Mar 29, 2023 11:54 pm
/export file=anynameyouwish (minus router serial number and any public WANIP Info )
Ca6ko
Long time Member
Long time Member
Thu Mar 30, 2023 12:42 pm
The automatic default route creation is disabled in the DHCP client.
It is the default route 0.0.0.0/0 that changes your settings, not the ones you indicated in the picture.
PS Personally, I prefer the option of switching routes via netwatch
laurenttaieb
Fri Mar 31, 2023 12:35 am
Hi, what would you suggest to avoid this misbehavior, My goal is to have the traffic routed via the WAN FTTP and the backup via the WAN 5G woud take over only if the router cannot ping addresses (Google DNS servers or others) not accessible via the WAN FTTH.
How would it work via netwatch ?
laurenttaieb
Fri Mar 31, 2023 1:06 am
Sure, shall I post or send it to you directly ?
Ca6ko
Long time Member
Long time Member
Fri Mar 31, 2023 9:27 am
You must disable the default route addition in the DHCP client settings.
laurenttaieb
Fri Mar 31, 2023 2:26 pm
Many thanks, it worked perfectly.
All resolved now !!
Users browsing this forum: GPH, nPaceTo and 40 guests
