csheadunternktik
WLAN Guest mode / WLAN different subnet while configured as bridge
Thu Mar 30, 2023 11:51 am
Hi. What would be the best way to set up two Mikrotik hAC ac2 for the following scenario
Mikrotik 1 -
Connected to my ISP's fiber box ( via eth1 ) and acts as the main router. The IP address range for this router is 192.168.99.1/24
Mikrotik 2 -
Connected to Mikrotik 1 via ethernet. Both Mikrotik 1 and Mikrotik 2 are in the same subnet ( ie. 192.168.99.1/24 ).
Wireless lan to have a different subnet ( 10.10.10.1/24 ) so that it won't have access to the 192.168.99.1/24 network
Note :
I used Quick set ( WISP ASP ) and set the configuration to bridge for the initial setup. I created a virtual wireless interface ( "wlan_guest" ), created a guest bridge ( bridge_guest ) and added wlan_guest as a port to bridge_guest. I was able to connect to the guest wifi but I wasn unable to get any internet connection.
anav
Re: WLAN Guest mode / WLAN different subnet while configured as bridge
Thu Mar 30, 2023 1:54 pm
First MT is a router, one bridge ( create the number of vlans as you have subnets on the network ), trunk port to second MT
Second MT is an AP/switch trunk port in on ether1, only vlan identified is trusted subnet on with interface being the bridge.
assign vlans to etherports and wlan ports as required.
Users browsing this forum: 0xAA55, Bing [Bot] and 60 guests
