papayanetwork
Wifi Disconnecting
Thu Mar 30, 2023 11:34 pm
Hey guys!
i'am newbie in mikrotik, but i cant understand my disconnecting device issue, look here-
https://prnt.sc/Ghf2EVn_izWo
can anybody explain me why?
AllexRo
Re: Wifi Disconnecting
Fri Mar 31, 2023 3:55 pm
You have to give more details:
- what device is it? android, ios? seems like an ios
- what's your router/ap configuration? depending on device, go in Winbox to terminal and write:
/interface/wireless export hide-sensitive
or if you have of the new AX devices:
/interface/wifiwave2 export hide-sensitive
and paste whatever is printed there into a code area
 to be easily read.
papayanetwork
Fri Mar 31, 2023 8:39 pm
oh sorry.
its hAP ax3.
Problem its on two iphone, one its X, second its 11
the funny thing its i didint notice any problems at my laptop. - ThinkPad x230
# mar/31/2023 19:33:49 by RouterOS 7.8
# software id = D80Q-HRRT
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDF08JCC20B
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.country=Poland .mode=ap .ssid=\
    testMT_5 disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Poland .mode=ap .ssid=testMT_2.4 \
AllexRo
Fri Mar 31, 2023 9:43 pm
Try with "Disable PMKID" on.
Forget network from both phones, register once again and see if the problem re-appears.
papayanetwork
Fri Mar 31, 2023 11:32 pm
okay i did that, i will let you know how its the status about it tommorow ;) thanks for reply buddy
papayanetwork
Fri Mar 31, 2023 11:37 pm
Still same, after 15 mins disconnected, now i connected android phone, and same problem
 22:36:32 wireless,info 44:18:FD:A9:3E:D6@wifi1 disconnected, connection lost, signal strength -42
 22:36:39 wireless,info 44:18:FD:A9:3E:D6@wifi1 connected, signal strength -44
papayanetwork
Sat Apr 01, 2023 3:04 pm
i got little edit for you, interesting thing noticed
https://prnt.sc/3lt8VcBIwErt
my pc working well on this 5g network, also i didnt notice any problem on my 2.4ghz network. Look at uptime.
optio
Long time Member
Long time Member
Sat Apr 01, 2023 8:00 pm
Are iPhones disconnecting when they are awake or just on standby?
In my case this is only happening when they go to standby (cca 30s after lock), on next awake they reconnect, this is normal behavior to save battery.
I dismissed for info log wireless topic (!wireless) because it bloats log with these messages.
Also it could be that you are on edge of 5ghz signal (laptops usually have larger antennas so they can on same place receive signal better than mobile phones, see image below), 2.4ghz has better coverage because penetrates better through solid objects, but from your logs signal strength looks ok.
papayanetwork
Sun Apr 02, 2023 6:18 pm
Problem exists when i normally use my iphone :(
bpwl
Sun Apr 02, 2023 6:26 pm
Add wifi to your log. The reason might be just shown in there
/system logging add topics=debug,wireless
papayanetwork
Mon Apr 03, 2023 9:36 pm
Okay i will. I will let you know guys. Thanks for replies :)
marsbeetle
Wed Apr 05, 2023 9:34 pm
It looks like you made some changes just before it started re-authenticating. I’ve seen this too on my ax3. I see in 7.9rc there are quite a few improvements with WifiWave2 and this:
*) wifiwave2 - fixed 802.11r roaming for clients that performed initial authentication with an AP which has been restarted since
I suspect your issue is related because changes usually cause radio to restart. I would also try keep both radio’s on the same SSID and don’t disable PMKID which is used for roaming. After 7.9 stable release I’m hoping to see a bit more stability in wifi with hAP ax3 and WifiWave2 devices in general.
Users browsing this forum: Google [Bot], normis and 88 guests
