myriad
Connect BELL fibre to Mikrotik RB2011??
Fri Mar 31, 2023 3:51 pm
Just wondering if it is possible to utilize a setup where I remove the SFP connector from a bell router and connect it to a Gigabit SFP to RJ45 Fiber Media Converter into my Mikrotik RB2011? I am successfully utilizing this technique with my PFsense appliance using VLAN35 and a ppoe client linked to the WAN input. I am not sure if the GPON supplied in the Giga hub modem is compatible with the RB2011, hence the media converter idea. I've already had some excellent help from Anav but I need to add a Wireguard tunnel as well to access the lan and also administer the MT remotely. Here is a network diagram of what I am trying to achieve:
Here is my current config:
# mar/31/2023 08:15:09 by RouterOS 7.8
# software id = 5MCY-99KG
# model = RB2011UiAS-2HnD
# serial number = XXX
add name=BR1 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] mtu=1508
/interface wireless
set [ find default-name=wlan1 ] frequency=auto mode=ap-bridge ssid=BLUE
/interface wireguard
add listen-port=13231 mtu=1392 name=WoodbineWG
/interface vlan
add interface=BR1 name=APT1_VLAN vlan-id=20
add interface=BR1 name=APT2_VLAN vlan-id=10
add interface=BR1 name=BASE_VLAN vlan-id=99
add interface=ether1 name=BELL_VLAN vlan-id=35
/interface pppoe-client
add add-default-route=yes interface=ether1 name=Virgin user=\
    xxx@virginmobile.ca
add name=WAN
add name=VLAN
add name=BASE
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=guest \
/interface wireless
add mac-address=E6:8D:8C:36:5C:C7 master-interface=wlan1 name=wlan2 \
    security-profile=guest ssid=GREEN
add name=APT1_POOL ranges=10.0.10.2-10.0.10.254
add name=APT2_POOL ranges=192.168.10.50-192.168.10.254
add name=BASE_POOL ranges=192.168.0.50-192.168.0.254
add address-pool=APT1_POOL interface=APT1_VLAN name=APT1_DHCP
add address-pool=APT2_POOL interface=APT2_VLAN name=APT2_DHCP
add address-pool=BASE_POOL interface=BASE_VLAN name=BASE_DHCP
/port
set 0 name=serial0
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=\
    ether2 pvid=20
    ether3 pvid=20
    wlan1 pvid=20
    wlan2 pvid=10
add bridge=BR1 comment="Admin Access" frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether5 pvid=99
add bridge=BR1 frame-types=admit-only-vlan-tagged interface=ether4
set discover-interface-list=BASE
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether4 untagged=wlan2 vlan-ids=10
add bridge=BR1 tagged=BR1,ether4 untagged=ether2,ether3,wlan1 vlan-ids=20
add bridge=BR1 tagged=BR1,ether4 untagged=ether5 vlan-ids=99
add interface=ether1 list=WAN
add interface=BASE_VLAN list=VLAN
add interface=APT1_VLAN list=VLAN
add interface=APT2_VLAN list=VLAN
add interface=BASE_VLAN list=BASE
/interface wireguard peers
add allowed-address=10.10.105.3/32 interface=WoodbineWG public-key=\
    "FTg+d2M/fWtPA/re9G9gUfZPt+qwsasfsfaUDm2obgJLDCc="
add address=192.168.0.1/24 interface=BASE_VLAN network=192.168.0.0
add address=10.0.10.1/24 interface=APT1_VLAN network=10.0.10.0
add address=192.168.10.1/24 interface=APT2_VLAN network=192.168.10.0
add address=10.10.105.1/24 interface=WoodbineWG network=10.10.105.0
/ip dhcp-client
add address=10.0.10.0/24 dns-server=192.168.0.1 gateway=10.0.10.1
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
set allow-remote-requests=yes servers=1.1.1.1
add action=accept chain=input dst-port=51820 protocol=udp
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=forward in-interface=WoodbineWG
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" \
    in-interface=BASE_VLAN
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=input dst-port=51820 in-interface=WoodbineWG \
    protocol=tcp
add action=accept chain=input comment="Allow Subnet and WG to internet" \
add action=accept chain=input comment="allow all from LAN" in-interface=\
    ether1
add action=accept chain=input dst-port=443 protocol=udp
add action=drop chain=input comment=Drop
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment="Default masquerade" \
add action=masquerade chain=srcnat out-interface=ether1 src-address=\
    192.168.0.0/24
/ip service
set www-ssl disabled=no
/lcd interface pages
set 0 interfaces="sfp1,ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8\
    ,ether9,ether10"
/system clock
set time-zone-name=America/Toronto
/system identity
set name=RouterSwitchAP
/system script
add dont-require-permissions=no name=script1 owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
    ####\r\
    \n# Topic:\t\tUsing RouterOS to VLAN your network\r\
    \n# Example:\t\tRouter-Switch-AP all in one device\r\
    \n# Web:\t\t\thttps://forum.mikrotik.com/viewtopic.php\?t=143620\r\
    \n# RouterOS:\t\t6.47.10\r\
    \n# Date:\t\t\tFebruary 17, 2023\r\
    \n# Notes:\t\tStart with a reset (/system reset-configuration)\r\
    \n# Thanks:\t\tmkx, sindy\r\
    \n########################################################################\
    #######\r\
    \n\r\
    \n#######################################\r\
    \n# Naming\r\
    \n\r\
    \n# name the device being configured\r\
    \n/system identity set name=\"RouterSwitchAP\"\r\
    \n\r\
    \n\r\
    \n# VLAN Overview\r\
    \n\r\
    \n# 10 = BLUE\r\
    \n# 20 = GREEN\r\
    \n# 99 = BASE (MGMT) VLAN\r\
    \n\r\
    \n\r\
    \n# WIFI Setup\r\
    \n#\r\
    \n# Example wireless settings only. Do\r\
    \n# NOT use in production!\r\
    \n\r\
    \n# Blue SSID\r\
    \n/interface wireless security-profiles set [ find default=yes ] authentic\
    ation-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key=\"password\"\r\
    \n/interface wireless set [ find default-name=wlan1 ] ssid=BLUE frequency=\
    auto mode=ap-bridge disabled=no\r\
    \n\r\
    \n# Green SSID\r\
    \n/interface wireless security-profiles add name=guest authentication-type\
    \n/interface wireless add name=wlan2 ssid=GREEN master-interface=wlan1 sec\
    urity-profile=guest disabled=no\r\
    \n\r\
    \n\r\
    \n# Bridge\r\
    \n\r\
    \n# create one bridge, set VLAN mode off while we configure\r\
    \n/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no\r\
    \n\r\
    \n\r\
    \n#\r\
    \n# -- Access Ports --\r\
    \n#\r\
    \n\r\
    \n# ingress behavior\r\
    \n/interface bridge port\r\
    \n\r\
    \n# Blue VLAN 20\r\
    \nadd bridge=BR1 interface=ether2 pvid=20\r\
    \nadd bridge=BR1 interface=ether3 pvid=20\r\
    \nadd bridge=BR1 interface=wlan1  pvid=20\r\
    \n\r\
    \n# Green VLAN 10\r\
    \nadd bridge=BR1 interface=ether4 pvid=10\r\
    \nadd bridge=BR1 interface=wlan2  pvid=10\r\
    \n\r\
    \n# BASE_VLAN, set aside a port for admin access to Winbox the device.\r\
    \nadd bridge=BR1 interface=ether5 pvid=99\r\
    \n\r\
    \n# egress behavior, handled automatically\r\
    \n\r\
    \n# L3 switching so Bridge must be a tagged member\r\
    \n/interface bridge vlan\r\
    \nadd bridge=BR1 tagged=BR1 vlan-ids=10\r\
    \nadd bridge=BR1 tagged=BR1 vlan-ids=20\r\
    \nadd bridge=BR1 tagged=BR1 vlan-ids=99\r\
    \n\r\
    \n\r\
    \n# IP Addressing & Routing\r\
    \n\r\
    \n# LAN facing router's IP address on the BASE_VLAN\r\
    \n/interface vlan add interface=BR1 name=BASE_VLAN vlan-id=99\r\
    \n/ip address add address=192.168.0.1/24 interface=BASE_VLAN\r\
    \n\r\
    \n# DNS server, set to cache for LAN\r\
    \n/ip dns set allow-remote-requests=yes servers=\"9.9.9.9\"\r\
    \n\r\
    \n# Yellow WAN facing port with IP Address and route provided by ISP\r\
    \n/ip address add interface=ether1 address=a.a.a.a/aa network=a.a.a.0\r\
    \n/ip route add distance=1 gateway=b.b.b.b\r\
    \n\r\
    \n\r\
    \n# IP Services\r\
    \n\r\
    \n# Blue VLAN interface creation, IP assignment, and DHCP service\r\
    \n/interface vlan add interface=BR1 name=BLUE_VLAN vlan-id=20\r\
    \n/ip address add interface=BLUE_VLAN address=10.0.10.1/24\r\
    \n/ip pool add name=BLUE_POOL ranges=10.0.10.2-10.0.10.254\r\
    \n/ip dhcp-server add address-pool=BLUE_POOL interface=BLUE_VLAN name=BLUE\
    _DHCP disabled=no\r\
    \n/ip dhcp-server network add address=10.0.10.0/24 dns-server=192.168.0.1 \
    gateway=10.0.10.1\r\
    \n\r\
    \n# Green VLAN interface creation, IP assignment, and DHCP service\r\
    \n/interface vlan add interface=BR1 name=GREEN_VLAN vlan-id=10\r\
    \n/ip address add interface=GREEN_VLAN address=192.168.10.1/24\r\
    \n/ip pool add name=GREEN_POOL ranges=192.168.10.50-192.168.10.254\r\
    \n/ip dhcp-server add address-pool=GREEN_POOL interface=GREEN_VLAN name=GR\
    EEN_DHCP disabled=no\r\
    \n/ip dhcp-server network add address=192.168.10.0/24 dns-server=192.168.1\
    0.1 gateway=192.168.10.1\r\
    \n\r\
    \n# Optional: Create a DHCP instance for BASE_VLAN. Convenience feature fo\
    r an admin.\r\
    \n /ip pool add name=BASE_POOL ranges=192.168.88.10-192.168.0.254\r\
    \n /ip dhcp-server add address-pool=BASE_POOL interface=BASE_VLAN name=BAS\
    E_DHCP disabled=no\r\
    \n /ip dhcp-server network add address=192.168.88.0/24 dns-server=192.168.\
    88.1 gateway=192.168.88.1\r\
    \n\r\
    \n\r\
    \n# Firewalling & NAT\r\
    \n# A good firewall for WAN. Up to you\r\
    \n# about how you want LAN to behave.\r\
    \n\r\
    \n# Use MikroTik's \"list\" feature for easy rule matchmaking.\r\
    \n\r\
    \n/interface list add name=WAN\r\
    \n/interface list add name=VLAN\r\
    \n/interface list add name=BASE\r\
    \n\r\
    \n/interface list member\r\
    \nadd interface=ether1     list=WAN\r\
    \nadd interface=BASE_VLAN  list=VLAN\r\
    \nadd interface=BLUE_VLAN  list=VLAN\r\
    \nadd interface=GREEN_VLAN list=VLAN\r\
    \nadd interface=BASE_VLAN  list=BASE\r\
    \n\r\
    \n# VLAN aware firewall. Order is important.\r\
    \n/ip firewall filter\r\
    \n\r\
    \n\r\
    \n##################\r\
    \n# INPUT CHAIN\r\
    \nadd chain=input action=accept connection-state=established,related comme\
    nt=\"Allow Estab & Related\"\r\
    \n\r\
    \n# Allow VLANs to access router services like DNS, Winbox. Naturally, you\
    \_SHOULD make it more granular.\r\
    \nadd chain=input action=accept in-interface-list=VLAN comment=\"Allow VLA\
    N\"\r\
    \n\r\
    \n# Allow BASE_VLAN full access to the device for Winbox, etc.\r\
    \nadd chain=input action=accept in-interface=BASE_VLAN comment=\"Allow Bas\
    e_Vlan Full Access\"\r\
    \n\r\
    \nadd chain=input action=drop comment=\"Drop\"\r\
    \n\r\
    \n# FORWARD CHAIN\r\
    \nadd chain=forward action=accept connection-state=established,related com\
    ment=\"Allow Estab & Related\"\r\
    \n\r\
    \n# Allow all VLANs to access the Internet only, NOT each other\r\
    \nadd chain=forward action=accept connection-state=new in-interface-list=V\
    LAN out-interface-list=WAN comment=\"VLAN Internet Access only\"\r\
    \n\r\
    \nadd chain=forward action=drop comment=\"Drop\"\r\
    \n\r\
    \n# NAT\r\
    \n/ip firewall nat add chain=srcnat action=masquerade out-interface-list=W\
    AN comment=\"Default masquerade\"\r\
    \n\r\
    \n\r\
    \n# VLAN Security\r\
    \n\r\
    \n# Only allow ingress packets without tags on Access Ports\r\
    \nset bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and\
    -priority-tagged [find interface=ether2]\r\
    -priority-tagged [find interface=ether3]\r\
    -priority-tagged [find interface=ether4]\r\
    -priority-tagged [find interface=ether5]\r\
    -priority-tagged [find interface=wlan1]\r\
    -priority-tagged [find interface=wlan2]\r\
    \n\r\
    \n\r\
    \n# MAC Server settings\r\
    \n\r\
    \n# Ensure only visibility and availability from BASE_VLAN, the MGMT netwo\
    rk\r\
    \n/ip neighbor discovery-settings set discover-interface-list=BASE\r\
    \n/tool mac-server mac-winbox set allowed-interface-list=BASE\r\
    \n/tool mac-server set allowed-interface-list=BASE\r\
    \n\r\
    \n\r\
    \n# Turn on VLAN mode\r\
    \n/interface bridge set BR1 vlan-filtering=yes\r\
    \n\r\
    \n"
add dont-require-permissions=no name=script2 owner=admin policy=\
    \_Blue VLAN interface creation, IP assignment, and DHCP service\r\
    \n\r\
    \n\r\
    r an admin.\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n# INPUT CHAIN\r\
    \n\r\
    N\"\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n# NAT\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    \n\r\
    rk\r\
    \n\r\
    \n\r\
    \n"
/tool mac-server
One other thing: I started this config using an example found in another thread and it seems that much of the original config still seems to be there, though in a commented out form (\n). Any idea how I can clean up this config file?
404Network
Re: Connect BELL fibre to Mikrotik RB2011??
Fri Mar 31, 2023 4:05 pm
Depends, where are you located??
Also if you had bothered to do a search!!!
viewtopic.php?p=989737&hilit=Bell#p989737
and of course the infamous thread
https://www.dslreports.com/forum/r31118 ... meHub-3000
myriad
Fri Mar 31, 2023 4:58 pm
Yep, read both those threads thanks. I was wondering if anyone on these forums has any success using a sfp to ethernet converter. My Pfsense works great so I might just buy another PFs router and toss the Mikrotik if I have to. I just hate wasting perfectly good hardware as I'd rather keep it out of the landfill if I can.
404Network
Fri Mar 31, 2023 6:03 pm
RB2011 is old news, probably time for the landfill anyway.
Users browsing this forum: adwlodaro, lego11 and 66 guests
