z4ki
Packet loss and RX Drops on 10G SFP+ X86_64
Fri Mar 31, 2023 9:39 pm
Facing packet loss and RX drops issue on my Mikrotik x86 with 10G NIC, my current traffic is over 2200 Mbps. WAN port is connected through Optical Fiber and LAN port is connected to a distribution router (Mikrotik 1036 2S+) through 10G DAC Cable.
ROS: 6.49.7
16 Gig Ram
2x Xeon Processors (24 Cores) 2.5Ghz
2x SFP+ Ports - Intel 82599EB 10-Gigabit Network Connection (rev: 1)
RouterOS is on SSD
Current Traffic: 2.2Gbps +
WAN Connected From CRS317-1G-16S+ (Optical Power TX:-1.988dBm, RX:-6.391dBm)
70 Simple Queue with 10 PCQ and 1 NAT Rule, 1 Mangle Rule
5 BGP Peer with 6500+ route
bodmas79
Re: Packet loss and RX Drops on 10G SFP+ X86_64
Tue Apr 02, 2024 9:34 am
How did you solve the problem?
z4ki
Tue Apr 02, 2024 1:31 pm
Yes, I solved the issue by changing SFP Module.
Users browsing this forum: No registered users and 156 guests
