WN1X
FIOS IPv6 issues
Fri Mar 31, 2023 9:56 pm
I've been struggling with getting IPv6 working with my new RB4011 and could use some suggestions. IPv6 works correctly with my old router.
Current config:
/ipv6 dhcp-server
add address-pool=WAN6 interface=bridge lease-time=1d name=default \
    rapid-commit=no
/ipv6 pool
add name=WAN6 prefix=::/56 prefix-length=64
/ipv6 settings
set accept-router-advertisements=yes
/ipv6 address
add address=::1 from-pool=WAN6 interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=ether1 pool-name=WAN6 prefix-hint=::/56 \
    rapid-commit=no request=prefix use-interface-duid=yes use-peer-dns=no
/ipv6 nd
set [ find default=yes ] disabled=yes managed-address-configuration=yes \
    other-configuration=yes
add advertise-mac-address=no dns=2606:4700:4700::1111 hop-limit=64 interface=\
    bridge other-configuration=yes
add advertise-dns=no advertise-mac-address=no interface=ether1 \
    managed-address-configuration=yes other-configuration=yes
/ipv6 nd prefix
add autonomous=no interface=bridge
My testing currently shows:
[admin@MikroTik] > ipv6/dhcp-client/print
Columns: INTERFACE, STATUS, REQUEST, PREFIX
# INTERFACE  STATUS  REQUEST  PREFIX
0 ether1     bound   prefix   2600:4040:xxxx:xxxx::/56, 1h50m36s
[admin@MikroTik] > ipv6/route/print
Flags: D - DYNAMIC; A - ACTIVE; c, d, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS               GATEWAY                           DISTANCE
DAd ::/0                      fe80::cee1:7fff:fea9:5bc9%ether1         1
DAd 2600:4040:xxxx:xxxx::/56                                           1
DAc fde7:3e68:4330:4644::/64  bridge                                   0
DAc fe80::%ether1/64          ether1                                   0
DAc fe80::%bridge/64          bridge                                   0
Any suggestions would be greatly appreciated.
tdw
Re: FIOS IPv6 issues
Sat Apr 01, 2023 12:38 am
Unless you need a DHCPv6 server to hand out prefixes and other information to your devices it is not necessary to create one under /ipv6 dhcp-server - specifically it does not provide individual addresses, clients must use SLAAC, static addresses or another DHCPv6 server on your network.
Do not set add-default-route=yes under /ipv6 dhcp-client - this is a hack as DHCPv6 has no mechanism to provide gateway information, and unnecessary if RAs are being received.
The /ipv6 nd entry for interface=ether1 is unnecessary as it is only receiving information. The other-configuration=yes for interface=bridge is only necessary if you wish client devices to request additional data from the DHCPv6 server. There should be no need to add any /ipv6 nd prefix entries.
It isn't clear where the ULA address on the bridge interface is being generated.
WN1X
Sun Apr 02, 2023 12:14 am
The DHCPv6 server was there to hand out DNS servers.
I removed the add-default-route on the dhcp-client and deleted the extra nd entry for ether1. Still no luck obtaining IPv6 for my clients.
Current config:
/ipv6 dhcp-server
    rapid-commit=no
/ipv6 pool
/ipv6 settings
/ipv6 address
/ipv6 dhcp-client
add interface=ether1 pool-name=WAN6 prefix-hint=::/56 rapid-commit=no \
/ipv6 nd
/ipv6 nd prefix
Still not sure what the problem might be.
[admin@MikroTik] > ipv6/address/print
Flags: I, D - DYNAMIC; G, L - LINK-LOCAL
Columns: ADDRESS, FROM-POOL, INTERFACE, ADVERTISE
#    ADDRESS                       FROM-POOL  INTERFACE  ADVERTISE
0 DL fe80::4aa9:8aff:fe66:b837/64             bridge     no
1 DL fe80::6662:66ff:fe21:1891/64             ether1     no
2 IG ::1/64                        WAN6       bridge     yes
DAd 2600:4040:591b:7a00::/56                  1
0 ether1     bound   prefix   2600:4040:591b:7a00::/56, 1h49m
tdw
Sun Apr 02, 2023 12:33 am
Is the WAN connectivity working, i.e. can you ping or traceroute from the Mikrotik to external IPv6 hosts?
Something isn't correct as the LAN address isn't being assigned:
If you are only using DHCPv6 to hand out DNS, and potentially other DHCP options, there is no need to for it to reference the pool or to specify a lease time. In v6 I use:
/ipv6 dhcp-server
add dhcp-option=XXXXX interface=bridge name=default
The newer versions of v7 support router advertisments including DNS, so if clients support that you may not need DHCPv6.
WN1X
Sun Apr 02, 2023 2:53 pm
Ping fails from the router:
[admin@MikroTik] > ping 2607:f8b0:4006:822::200e
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0                                                              no route to host
    1                                                              no route to host
    2                                                              no route to host
    3                                                              no route to host
    4                                                              no route to host
    sent=5 received=0 packet-loss=100%
The RB4011 is running v7.8 code. Verizon provides only a prefix (no WAN IP), but that works fine with my OPNSense firewall.
tdw
Re: FIOS IPv6 issues  [SOLVED]
Sun Apr 02, 2023 3:44 pm
Remove
/ipv6 pool
this is likely creating a static pool with an address of zero giving rise to the invalid address being assigned to the bridge interface, the IPv6 DHCP client will dynamically create the pool when a prefix is acquired.
WN1X
Sun Apr 02, 2023 4:27 pm
That was the cause of the problem. All is good now.
Thanks for the assistance!
Users browsing this forum: CGGXANNX, seriosha and 57 guests
