ljp379
Which router model for Internet Cafe (150 PCs)?
Sat Apr 01, 2023 7:00 am
Hi, Mikrotik members.
I'm running Internet Cafe and decide to. Hange router to Mikrotik finally.
Our cafe has 150 clients and 1Gbps fibre internet and needs to setup bandwidth control, game priority and anti hacking.
I have RB4011 and tested last year. But it was hacked like DDOS attack and changed to normal QoS router.
Is the RB4011 enough for 150 client PCs?
Can you recommend which model is enough for internet cafe?
CCR2004?
How about computer router? (i5 - 7400 , 16g ram?)
Can you recommend computer hardware spec if I go with PC?
anav
Re: Which router model for Internet Cafe (150 PCs)?
Sat Apr 01, 2023 10:40 pm
RB5009 should be fine for internet cafe.
There is no router on MT that will prevent DDOs attack, seems like your iSP failed to protect you from the last one.
The only method I am aware of, and one that apparently works, is linked here......... https://github.com/team-cymru/network-s ... /README.md
Suggest using remotewinbox which has partnered (signed up) with Team cymru to provide that level of protection.
Otherwise also suggest as a provider of a decent blacklist etc............ https://itexpertoncall.com/promotional/moab.html
Finally, the only additional suggestions for firewall along with default settings are found at apprentice setup here - viewtopic.php?t=180838
Rox169
Sat Apr 01, 2023 11:07 pm
Hi, Mikrotik has their oven script for ddos attack
https://help.mikrotik.com/docs/pages/vi ... d=28606504
But if there will be big attack no hw will help you...only Google cloud Armor can protect you...which is paid...
https://cloud.google.com/blog/products/ ... illion-rps
chechito
Sun Apr 02, 2023 12:14 am
if you already have it available go with it, it will perform better than a rb4011/rb5009
mpuria
Sun Apr 02, 2023 7:41 am
RB4011 should be able to handle more than 150PCs and your bandwidth as well.
With regards to your DDoS issue, it's possible that your ISP failed protection in their end, but nevertheless, if you configure properly your firewall rules, you could easily protect your network.
anav
Sun Apr 02, 2023 2:42 pm
Baloney, your router cannot protect you against a DDOS attack....... why do people keep spreading this fud..........
ljp379
Sun Apr 02, 2023 2:47 pm
Thank you Chechito.
Is the i5-7400 better than CCR2004?
ljp379
Sun Apr 02, 2023 2:48 pm
Thank you guys.
Your posts are very helpful. :)
jvanhambelgium
Forum Veteran
Forum Veteran
Sun Apr 02, 2023 8:57 pm
Thank you Chechito.
Better? you only have 150 clients and 1Gbits at most.
i5 is even overkill. RB4011 or RB5009 will serve your Internet Cafe without even running hot ;-)
Difficult to compare Intel i5 vs ARM64-chipset in detail.
Users browsing this forum: Semrush [Bot], yosue111 and 67 guests
