zhup
Transfer the Mikrotik license from one pc or hard disk to another one
Sat Apr 01, 2023 9:44 pm
Is it possible to transfer the Mikrotik license from one pc or hard disk to another one?
sid5632
Long time Member
Long time Member
Re: Transfer the Mikrotik license from one pc or hard disk to another one
Sun Apr 02, 2023 12:39 am
No, unless it's a CHR.
zhup
Sun Apr 02, 2023 1:36 pm
I found an information about this topic in: https://help.mikrotik.com/docs/display/ ... icense+key
Below the rules:
Replacement Key
It is a special key which is issued by the MikroTik support team if you accidentally lose the license on a x86 instance running RouterOS, and the Mikrotik Support employee decides that it is not directly your fault. It costs 10$ and has the same features as the key that you lost.
Note that before issuing such key, Mikrotik Support can ask you to prove that the old drive has failed, in some cases, this means sending us the dead drive.
BartoszP
Sun Apr 02, 2023 8:03 pm
There is a difference between "move" & "recovery" procedure.
Licence is bound to HDD so you can move this HDD to the new PC and the ROS will start.
rextended
Wed May 03, 2023 2:21 pm
@zhup
[ color=#FFFFFF].[/color ]
Why you continue uselessly to add white dot on forum?
You want replace it later with spam link?
Stop that behaviour.
Users browsing this forum: GoogleOther [Bot] and 134 guests
