PsYcH
Using WLAN1 as WAN - no internet in bridge or any other ETH port
Sun Apr 02, 2023 3:42 pm
What I want to reach, from the first look, quite simple network configuration, but I must be missing some thick box or whatever to make it work. My plan is to use my hAP ac2 as wireless ap bridge for my ETH ports, so I have reseted it, applied default configuration with defaut DHCP settings, changed my WAN port to WLAN1 port, changed masquarade rule interface to WLAN1, changed DHCP client interface to WLAN1, removed WLAN1 from bridge, added ETH1 to bridge. Looks quite simple, but it doesn`t work. WLAN1 interface have internet, but other ports dont. Clients under ETH ports can have their own dhcp pool, it doesn`t really matter for me if they get IP from DHCP client too. Attaching my configuration.
# apr/02/2023 15:36:22 by RouterOS 6.48.2
# software id = PQS8-A4IC
# model = RBD52G-5HacD2HnD
# serial number = A6470A812FD9
add admin-mac=74:4D:28:8B:77:8A auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors \
    installation=indoor mode=station-pseudobridge ssid=Valanda5EUR \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=MikroTik-8B778F \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
add comment=defconf interface=wlan1 list=WAN
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=wlan1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    ipsec-policy=out,none out-interface=wlan1 out-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
    ipsec-policy=out,none out-interface=bridge
/system clock
set time-zone-name=Europe/Vilnius
/tool mac-server
/tool mac-server mac-winbox
anav
Re: Using WLAN1 as WAN - no internet in bridge or any other ETH port
Sun Apr 02, 2023 3:48 pm
what is the purpose of this rule......??
PsYcH
Sun Apr 02, 2023 4:39 pm
Ah it was created for testing purposes, it is disabled.
holvoetn
Sun Apr 02, 2023 6:10 pm
What happens if you put wlan interface in mode station ?
As it happens to be, just saw another thread with similar issues.
These instructions where referred to (they are pretty good, if you follow them)
https://systemzone.net/wifi-station-set ... ss-router/
PsYcH
Sun Apr 02, 2023 7:10 pm
If I put it in station mode, nothing changes, I already have tried different types like station, station bridge, station pseudobridge - none of them helps. Also, reseted router again and followed the tutorial you sent me and guess what - it doesn`t work either :)
anav
Sun Apr 02, 2023 7:19 pm
Can you even confirm that you are connecting to your wireless source and getting a WANIP??
PsYcH
Mon Apr 03, 2023 3:09 pm
Yes, and i can ping 8.8.8.8 if I select WLAN1 as source, even can not choose source - it`s working, but if I choose source any ETH - it doesn`t
PsYcH
Sun Apr 09, 2023 8:48 pm
Any thoughts?
bpwl
Sun Apr 09, 2023 9:57 pm
Strange ....
How to choose an ethernet interface? They are all slave interfaces to the bridge. (They even have no IP address!)
I suspect the DHCP lease information received by the DHCP client.
Is default route and DNS set correctly by that DHCP server on WLAN1 ???
Use "station" , not "station-pseudobridge" ! For "station-pseudobridge" you intent to use the DHCP range of the DHCP server facing WLAN1, and then have WLAN1 also connected to the bridge, and no local DHCP server.
viewtopic.php?t=192945#p980385
broderick
Thu Apr 13, 2023 3:27 pm
first of all,
- Which kind of device are you trying to connect to via WLAN1 in wireless? And what IP do you get on the WAN side?
- Set mode from station-pseudobridge to station
- it's not that it is going to make any difference but:
why do you set out-interface=wlan1 out-interface-list=WAN? One of two would be ok already
- Did you make sure that your LAN client gets an ip address in the rage 192.168.88.10-192.168.88.254?
- I can't see any DNS setup on your LAN. - Can you ping 8.8.8.8 from a client in your LAN at least?
Users browsing this forum: jericho, nhongooi, Shambler and 38 guests
