m3das
Improve my script
Sun Apr 02, 2023 8:37 pm
Hello, everyone seems that I am not satisfied with my script.
This script works, need help if anyone can improve it?
:local un "user1"
/ip hotspot user set limit-uptime=0s [find where name=$un]
/ip hotspot user set comment="" [find where name=$un]
/ip hotspot user reset-counters [find where name=$un]
rextended
Re: Improve my script
Sun Apr 02, 2023 9:40 pm
But if you don't explain what you want to do, what do you want to be told?
m3das
Mon Apr 03, 2023 7:37 am
Hi sir extended,
Thank you for the replay,
The user has a monthly validity profile when the user goes beyond validation the user will disconnect from the hotspot. In order to renew/extend the validity of users, I need to clear the user's session in order to log back in. So I made a script for every user to renew their validity.
m3das
Mon Apr 03, 2023 8:10 am
or making the script shorter or in one line with the same function.
Users browsing this forum: No registered users and 26 guests
