aleab
rb4011 and cable check
Tue Apr 04, 2023 8:39 am
There is a way to check a cable with uplink active?
I have a device that negotiation 100m but is gigabit.
I think is cable, but i'm not on customer site.
So i can remotely access ti rb4011 and see port is running but 100m (not 1gb).
I try ti click cable check but tell me link Is active (no lenght no open circuit).
If not i plan to go onsite
Thank you
Ca6ko
Long time Member
Long time Member
Re: rb4011 and cable check
Tue Apr 04, 2023 3:48 pm
The cable tester only works with the cable disconnected.
If the link works, the cable cannot be tested. Only with a special tester. Check whether the auto-negotiation or manual is set.
Do not forget to turn on the safe mode when working remotely.
aleab
Tue Apr 04, 2023 7:40 pm
ok big thank you.
i plan to go onsite and check with a cable tester...
thank you
Users browsing this forum: No registered users and 53 guests
