I use these in PTMP deployments as well, with OmniTik 5AC's as the 5GHz AP and its POE out powering a couple of wAP60's at half of my MikroTik-based sites. The rest are 60GHz-only to wAP60's.
The bond on the CPE side is active/passive, with the 60GHz as primary, and all of the AP's (5GHz + 60GHz) in the same Layer 2 VLAN. (For a 60GHz-only AP, I disable the 5GHz radio.) It works very well, and I've had no complaints.
The majority of my CPE are the old Cube 60G's (CubeG5ac60ad), but I have some the newer Cube 60 Pro's as well. All of them work fine on 60GHz, with 6.49 or 7.12.
I really appreciate your insight.. I hate to push you to another post, but I posted the config that worked for me on the bench.. but I have yet to try it out in the wild yet.. but have a few events coming up and im planning on using the same solution for multiple locations.. id love to know if im barking up the right tree..
Thank you so much..
viewtopic.php?t=203524
