markus61
chateau 5g no lte1 interface
Wed Apr 05, 2023 11:18 pm
hey,
i'm lost. my chateau 5g does not bring up its lte1 interface.
the device runs routerOS 7.8.
whatever i do, quick set reports "Couldn't change LTE AP - LTE Interface is not ready! (6)"
this is what cli gives me:
[admin@MikroTik] > /interface lte set lte1 apn-profiles=internet.v6
no such item
if i try printing the interfaces i receive nothing but an empty line:
[admin@MikroTik] /interface/lte> print
apparently it's not a hardware thing. lte1 is reporting on boot (log added below).
any input welcome.
thx,
/markus
00:00:54 lte,async lte1: sent AT E0 V1
00:00:55 lte,async lte1: rcvd OK
00:00:55 lte,async lte1: sent AT+QCFG="usbnet"
00:00:55 lte,async lte1: rcvd +QCFG: "usbnet",2
00:00:55 lte,async lte1: sent AT+CMEE=2
00:00:55 lte,debug lte1 mbim: wdm max tx 4096
00:00:55 lte,debug lte1 mbim: state 0=>1
00:00:55 lte,debug lte1 mbim: <<< open
00:00:55 lte,packet,raw lte1 mbim: wdm <<< send #1
00:00:55 lte,packet,raw lte1 mbim: 01000000 10000000 01000000 00100000
00:00:55 lte,async lte1: sent AT+CGREG=2
00:00:55 lte,async lte1: sent AT+CEREG=2
00:00:55 lte,async lte1: sent AT+CGMM
00:00:55 lte,async lte1: rcvd RG502Q-EA
00:00:55 lte,async lte1: sent AT+QURCCFG="urcport","all"
00:00:55 lte,async lte1: sent AT+EGMR=0,5
00:00:55 lte,async lte1: rcvd +EGMR: "P1Q21CS0A00215608"
00:00:55 lte,async lte1: sent AT+QSIMDET=1,1
00:00:55 lte,async lte1: sent AT+QGMR
00:00:55 lte,async lte1: rcvd RG502QEAAAR11A06M4G_01.001.01.001
00:00:55 lte,async lte1: sent AT+QNVFR="/nv/item_files/Thin_UI/enable_thin_ui_cfg"
00:00:55 lte,async lte1: rcvd +QNVFR: 01
00:00:55 lte,async lte1: sent AT+QCFG="pdp/duplicatechk"
00:00:55 lte,async lte1: rcvd +QCFG: "pdp/duplicatechk",0
00:00:55 lte,async lte1: sent AT+QNVW=5280,0,"0102000000000000"
00:00:55 lte,async lte1: sent AT+QCFG="ims"
00:00:55 lte,async lte1: rcvd +QCFG: "ims",0,0
00:00:55 lte,async lte1: sent AT+QUIMSLOT?
00:00:55 lte,async,event lte1: +QUIMSLOT: 1
00:00:55 lte,async lte1: sent AT+QNWCFG="csi_ctrl",1,1
00:00:55 lte,async lte1: sent AT+QNWCFG="data_path",1
00:00:55 lte,async lte1: sent AT+QNWCFG="dis_rplmnact",1
00:00:55 lte,async lte1: sent AT+QNWCFG="lte_csi_ext"
00:00:55 lte,async lte1: rcvd +QNWCFG: "lte_csi_ext",0
00:00:55 lte,async lte1: sent AT+QNWCFG="nr5g_csi_ext"
00:00:55 lte,async lte1: rcvd +QNWCFG: "nr5g_csi_ext",0
00:00:55 lte,async lte1: sent AT+QNWCFG="LTE_tx_pwr"
00:00:55 lte,async lte1: rcvd +QNWCFG: "lte_tx_pwr",0
00:00:55 lte,async lte1: sent AT+QNVFW="/nv/item_files/Thin_UI/enable_thin_ui_cfg",00
00:00:55 lte,async lte1: sent AT+QNWCFG="lte_csi_ext",1
00:00:55 lte,async lte1: sent AT+QNWCFG="nr5g_csi_ext",1
00:00:55 lte,async lte1: sent AT+QNWCFG="LTE_tx_pwr",1
00:00:55 lte,async lte1: sent AT+QNWCFG="NR5G_tx_pwr",1
00:00:58 lte,debug lte1 mbim: <<< open
00:00:58 lte,packet,raw lte1 mbim: wdm <<< send #2
00:00:58 lte,packet,raw lte1 mbim: 01000000 10000000 02000000 00100000
00:01:04 lte,debug lte1 mbim: <<< open
00:01:04 lte,packet,raw lte1 mbim: wdm <<< send #3
00:01:04 lte,packet,raw lte1 mbim: 01000000 10000000 03000000 00100000
00:01:09 interface,info ether1 link up (speed 1G, full duplex)
00:01:10 interface,info ether1 link down
00:01:13 interface,info ether1 link up (speed 1G, full duplex)
00:01:16 lte,debug lte1 mbim: <<< open
00:01:16 lte,packet,raw lte1 mbim: wdm <<< send #4
00:01:16 lte,packet,raw lte1 mbim: 01000000 10000000 04000000 00100000
00:01:31 ssh,info publickey accepted for user: admin
00:01:31 system,info,account user admin logged in from 192.168.88.100 via ssh
00:01:40 lte,debug lte1 mbim: <<< open
00:01:40 lte,packet,raw lte1 mbim: wdm <<< send #5
00:01:40 lte,packet,raw lte1 mbim: 01000000 10000000 05000000 00100000
00:02:28 lte,debug lte1 mbim: <<< open
00:02:28 lte,packet,raw lte1 mbim: wdm <<< send #6
00:02:28 lte,packet,raw lte1 mbim: 01000000 10000000 06000000 00100000
00:03:27 system,info,account user admin logged in from 192.168.88.100 via web
00:03:58 system,info,account user admin logged in from 192.168.88.100 via web
00:04:04 lte,debug lte1 mbim: <<< open
00:04:04 lte,packet,raw lte1 mbim: wdm <<< send #7
00:04:04 lte,packet,raw lte1 mbim: 01000000 10000000 07000000 00100000
00:06:49 interface,info ether1 link down
00:06:56 interface,info ether1 link up (speed 1G, full duplex)
00:07:16 lte,debug lte1 mbim: <<< open
00:07:16 lte,packet,raw lte1 mbim: wdm <<< send #8
00:07:16 lte,packet,raw lte1 mbim: 01000000 10000000 08000000 00100000
00:12:47 system,info,account user admin logged out from 192.168.88.100 via web
00:13:03 interface,info ether1 link down
00:13:05 interface,info ether1 link up (speed 1G, full duplex)
00:13:40 lte,debug lte1 mbim: <<< open
00:13:40 lte,packet,raw lte1 mbim: wdm <<< send #9
00:13:40 lte,packet,raw lte1 mbim: 01000000 10000000 09000000 00100000
Amm0
Re: chateau 5g no lte1 interface
Thu Apr 06, 2023 12:37 am
The "apn-profile" is a link to profile in /interface/lte/apn, not the actual APN. You need to set the APN in the "APN Profile", assuming defaults, it's
/interface/lte/apn/set apn=internet.v6 [find default]
Your APN mentions IPv6, so assuming you want IPv6 prefix go someplace....you'll need to specify the interface IPv6 is bridged to, assuming it the defaults and you want IPv6 on the bridge itself, the command is:
/interface/lte/apn/set ipv6-interface=[/interface/bridge/find] [find default]
markus61
Thu May 25, 2023 2:35 pm
hi Amm0,
thanx for replying to my problem report. unfortunately i'm still fighting that problem. took a break in between though :-)
this are my configured apns:
[markus@MikroTik] /interface/lte> apn/ print
Flags: * - DEFAULT
Columns: NAME, APN, ADD-DEFAULT-ROUTE, DEFAULT-ROUTE-DISTANCE
# NAME APN ADD-DEFAULT-ROUTE DEFAULT-ROUTE-DISTANCE
0 * default internet.telekom yes 2
1 t-d1.telekom internet.t-d1.de yes 2
2 telekom internet.v6.telekom yes 2
whichever profile i try, i never end up with an interface in whatsoever state:
[markus@MikroTik] /interface/lte> set lte1 apn-profiles=telekom
no such item
[markus@MikroTik] /interface/lte> set [find] apn-profiles=telekom
[markus@MikroTik] /interface/lte> print
still, logs pretend there is something existing that is labeled "lte1" it appears to be some kind of ghost interface as i don't manage to access it in any way:
May 25 13:29:48 10.11.10.3 lte,debug lte1 mbim: <<< open
May 25 13:29:48 10.11.10.3 lte,packet,raw lte1 mbim: wdm <<< send #11
May 25 13:29:48 10.11.10.3 lte,packet,raw lte1 mbim: 01000000 10000000 0b000000 00100000
any help very much appreciated.
thanx!
/markus
markus61
Thu May 25, 2023 2:56 pm
added a supout.rif
own3r1138
Long time Member
Long time Member
Thu May 25, 2023 3:01 pm
Supout file contains sensitive information. One should not share it publicly.
https://mikrotik.com/client/supout
markus61
Thu May 25, 2023 3:19 pm
supout of a bricked router makes it a bricked router in danger. ;-)
Users browsing this forum: almdandi and 73 guests
