jakir69
IP Routes can be disabled using scripting.
Thu Apr 06, 2023 3:26 pm
when using command line in mikrotik, to disable ip route manually
for ex: i enter
/ip route set disabled=yes 10 (number of route item)
if i add or remove routes the item number gets changed
i want to disable specific routes at specific intervals
so is there any way to disable/enable routes by identifying comment or something similar using scripting.
baragoon
Re: IP Routes can be disabled using scripting.  [SOLVED]
Thu Apr 06, 2023 3:29 pm
/ip/route/disable [find comment="$comment"]
rextended
Thu Apr 06, 2023 3:49 pm
Reply on compatible way, if the user use RouterOS v6, do not provide commands for RouterOS v7 only...
/ip route disable [find where comment~"search this text on the comment"]
Users browsing this forum: No registered users and 38 guests
