ahmedsf
No internet with Wireguard only when connect outside from lte connection
Sun Apr 09, 2023 7:39 am
i have successfully create a mikrotik Wireguard server and i connect to the server from my local lan with internet no problem
but when i connect to the server from outside with my mobile with lte no internet
can you help me?
Thank you
anav
Re: No internet with Wireguard only when connect outside from lte connection
Sun Apr 09, 2023 1:43 pm
As always without a network diagram and a config /export , its all opinion.
ahmedsf
Sun Apr 09, 2023 8:26 pm
thank you for your reply
Sorry, I'm not an expert in Mikrotik
this is some screenshot
If you mean any other information, please explain what I do
ahmedsf
Sun Apr 09, 2023 8:34 pm
and this a config of Wireguard
anav
Sun Apr 09, 2023 8:36 pm
A network diagram shows all the connected devices and subnets/vlans addresses ports etc.......
many tools here check out network diagram apps - viewtopic.php?p=908118
For an export of the config go to winbox and NEW terminal and at the command line type
/export file=anynameyouwish
Download it to your PC,
OPen it with notepad++
Remove serial number of device and put in fake numbers for any public WANIP information
Then post it here and use the code tags to mark the config, the entry above with a black square and white brackets ( on the same line as BOLD, UNDERLINE etc. )
anav
Sun Apr 09, 2023 8:37 pm
Not sure why you are using 443 for wg listening port, which is used for other things and thus could get confusing, try something like 15553
No need to sourcenat your wireguard traffic in this case...... but will wait for config to see.
ahmedsf
Sun Apr 09, 2023 10:49 pm
Supplement according to what I understood from the topic network diagram
and export config file
I tried another port before but it didn't work either as 44355
thanks
ahmedsf
Thu Apr 13, 2023 11:22 pm
thank you
Did you notice anything abnormal in the settings?
anav
Fri Apr 14, 2023 12:43 am
You have failed to provide evidence, aka the config as requested.
If you need bettter guidance check out Para B! --> viewtopic.php?t=191442
ahmedsf
Fri Apr 14, 2023 1:40 am
sorry i delete the file by mistake
Users browsing this forum: No registered users and 46 guests
