maraschin89
Issue connecting to internet
Mon Apr 10, 2023 2:41 pm
I'm in desperate need of some help getting my Microtik Anntena to work
Model: ATL LTE 18 Kit
Issue: not connecting to the internet or updating software.
Error when trying to update: Error: cannot resolve DNS
Current state and installation
- I am using the web interface of RouterOS (7.4.1) - MAC O.S -
- connected ethernet directly from the antenna to the laptop
- Disabled DHCP - set static IP address to 192.168.1.1
- LTE status (LTE 4G is connected and shows strong signal strength and APN details, carrier details, etc)
- DNS setting currently shows 0.0.0.0 (no matter what I put in here same issue)
I have used other previous LTE antenna models and they just worked once connected. Is there anything that needs configuring that I am not aware of?
My Main goal - I want to connect the Antenna directly to my TP-Link Deco M5 (mesh network) as the source of internet to the current Deco network. The Deco has DHCP.
Any help and assistance in troubleshooting this issue would be greatly appreciated.
derfred
Re: Issue connecting to internet
Tue Apr 11, 2023 11:55 pm
I have the exact same problem here.
Tried on a routers wan port where I had the SXT connected and nothing, connected directly to the imac ethernet port and can access the http://192.168.188.1 page, the lte connection is good, no sim pin as usual but nothing from the lte is being passed to the router or computer imho.
I have an sxt lte5 that worked like a charm. Got this to improve the quality of the connection and just can´t make it work.
The config being used is the basic configuration that comes with the equipment, done several factory resets so nothing changed
Please help!
derfred
Fri Apr 28, 2023 1:27 pm
Bump
derfred
Wed May 03, 2023 2:04 pm
Try this command:
interface/lte/apn/set [find default] use-network-apn=no
From Elvijs from tech support
Mine updated and its working now
xSoul
Fri Jun 09, 2023 12:03 am
Hi
I have the same problem.
Good connection but no internet.
The lte antenna get private ip but still no internet
I set correct apn and no pin to the sim card and update with the last release
Can you help me please?
Users browsing this forum: lurker888 and 99 guests
