VK2XXY
wAP R ac repair manual
Tue Apr 11, 2023 6:23 am
I have a wAP R ac that appears to have been damaged in a recent storm.
Both ethernet ports are dead but the power/usr leds operate.
I have seen out of warranty repair manuals for other mikrotik products.
Is there a repair/troubleshooting manual for the wAP R ac?
If not, is there any info about getting console access to the mainboard?
Regards,
William.
park2701
Re: wAP R ac repair manual
Tue Apr 11, 2023 7:10 am
There is hardware repair manual and manual for overvoltage checking but it is not opened for public.
Contact with your local distributor.
Amm0
Tue Apr 11, 2023 5:46 pm
If you reset to defaults (press reset ~7 seconds while powering)... the Wi-Fi should appear and you can at least see how damaged it from that.
VK2XXY
Wed Apr 12, 2023 7:04 am
Tried. No Wi-Fi shows up.
Last firmware was 7.8. Does that change anything?
Amm0
Wed Apr 12, 2023 7:19 am
Well that doesn't seem like good news. Maybe trying netinstall, and/or using different form of power (e.g. use PoE if you were using the 5.5/2.1 jack, or vise versa).
There are pad inside, but never messed with them. If netinstall didn't work, kinda tells you getting serial port from pads may not help since it both need RouterBOOT to work.
VK2XXY
Sat May 06, 2023 3:20 pm
From what I read production RouterBOOT does not have the serial console enabled for devices that have internal pads.
Netinstall would fail even if the damage was limited to the Ethernet ports. The inability to do a reset and get access to a default SSID is more telling of a complete meltdown.
I have tried a different power supply.
Users browsing this forum: No registered users and 38 guests
