shalak
Using variable as value for [/find] parameter
Wed Apr 12, 2023 1:25 pm
I have the following script:
/ip dns static
:foreach rec in=[find type=[]] do={
  :local name [get $rec name]
  :local address [get $rec address]
  :if ([:len $name] > 0) do={
    :put ("Checking A record: " . $rec . " [name=" . $name . ", address=" . $address . "]")
    :local expectedIpv6Address ("::ffff:" . $address)
    :local existingAAAARecordsWithThisName [find name=$name type=AAAA]
    :if ([:len $existingAAAARecordsWithThisName] > 0) do={
      :foreach existingAAAARecord in=$existingAAAARecordsWithThisName do={
        :put ("Removing old AAAA record: " . $existingAAAARecord . " [name=" . [get $existingAAAARecord name] . ", address=" . [get $existingAAAARecord address] . "]")
        # remove $existingAAAARecord
    :put ("Creating AAAA record for name=" . $name . " address=" . $expectedIpv6Address)
    # add name=$name address=$expectedIpv6Address type=AAAA
There's a problem with
- the value becomes an array of all AAAA entries, not just the one matching "name" - it's like the
$name
is not applied at all to the find function.
What am I missing?
rextended
Re: Using variable as value for [/find] parameter
Wed Apr 12, 2023 2:03 pm
Why type=[] instead of !type ?
rextended
Wed Apr 12, 2023 2:14 pm
Simply do that.
/ip dns static
:foreach item in=[find where (!type or (type=A)) and ([:typeof $name]="str")] do={
    remove [find where (name=[get $item name]) and (type=AAAA)]
    add name=[get $item name] type=AAAA address=("::ffff:$[get $item address]")
Why complicate script with useless frills for debug???.......
shalak
Wed Apr 12, 2023 2:21 pm
I was not aware on how to use that, thanks for the hint!
To understand what's happening and not deploy the code that might break stuff. Mikrotik scripting has a lots of quirks, e.g. you might expect that [find type=A] would return a list of A records. But it doesn't. Hence the need to be verbose, especially while designing scripts. And the need to maintain them properly, e.g. in case a ROS update drops that breaks backwards compatibility.
Thank you for the suggestion, but I'm still unaware on why my solution doesn't work :/ Any suggestions? Is it a scoping issue (i.e. the [find ...] creates a new scope, in which the $name does not exist?)
rextended
Re: Using variable as value for [/find] parameter  [SOLVED]
Wed Apr 12, 2023 2:24 pm
Ok, this integrate debug...
/ip dns static
/ip dns static
    :local newadd ("::ffff:$[get $item address]")
    :local iname  [get $item name]
    :local removethis [find where (name=$iname) and (type=AAAA)]
    :foreach idx in=$removethis do={
        :put "Removing AAAA name $[get $idx name] with address $[get $idx address]"
    remove $removethis
    :put "Adding AAAA name $iname with address $newadd"
    add name=$iname type=AAAA address=$newadd
rextended
Wed Apr 12, 2023 2:27 pm
Warning, I fix a misspell error on previous post #3, check twice.
viewtopic.php?p=995896#p995891
Is why I write (!type or (type=A)) and not only !type
I write the description for your other question, please wait...
shalak
Wed Apr 12, 2023 2:32 pm
/ip dns static
        :put "Removing AAA record $[get $idx name] with address $[get $idx address]"
    remove $removethis
    :put "Adding AAAA record $iname with address $newadd"
    add name=[get $item name] type=AAAA address=$newadd
Thank you! Your script has helped me debug the underlying issue: the $name appears to be a reserved keyword, as soon as I changed it to $iname my script started to work correctly.
rextended
Wed Apr 12, 2023 2:35 pm
oh, i was writing to you...
bravo!
In fact that word is reserved in the context /ip dns static, if you notice I didn't declare "name" but I used it.... ;)
The problem on OP script is also the check "[:len $name] > 0".
Since the name can be nil is wrong compare "nil" with something...
I omith the check of the name because on the first query I request records of "type=A" that have the name specified ;)
rextended
Wed Apr 12, 2023 2:45 pm
Fixed "AAA" typo and one variable error (not used the existant variable, call again "get" instead) on script #5
You can do also the same for RegEx records.... ;)
Debug version
/ip dns static
:foreach item in=[find where (!type or (type=A)) and ([:typeof $regexp]="str")] do={
    :local iregex [get $item regexp]
    :local removethis [find where (regexp=$iregex) and (type=AAAA)]
        :put "Removing AAAA RegEx $[get $idx regexp] with address $[get $idx address]"
    remove $removethis
    :put "Adding AAAA RegEx $iregex with address $newadd"
    add regexp=$iregex type=AAAA address=$newadd
Short version
/ip dns static
    remove [find where (regexp=[get $item regexp]) and (type=AAAA)]
    add regexp=[get $item regexp] type=AAAA address=("::ffff:$[get $item address]")
shalak
Wed Apr 12, 2023 2:56 pm
bravo!
Thank you for the insights!
I even went further and upgraded the solution like this:
/ip dns static
:foreach ARecord in=[find where (!type or (type=A)) and ([:typeof $name]="str")] do={
    :local correctIpv6 ("::ffff:$[get $ARecord address]")
    :local iname [get $ARecord name]
    :local wrongAAAA [find where (name=$iname) and (type=AAAA) and !(address=$correctIpv6)]
    :local correctAAAA [find where (name=$iname) and (type=AAAA) and (address=$correctIpv6)]
    :foreach idx in=$wrongAAAA do={
        remove $idx
    :if ([:len $correctAAAA] = 0) do={
        :put "Adding AAAA record $iname with address $correctIpv6"
        add name=$iname type=AAAA address=$correctIpv6
That way, I can run this in scheduler every couple of minutes and nothing will happen if all the AAAA records are aligned properly to their corresponding A records.
I hope it's not too much to ask - would you mind proof-checking for some pitfalls, I might not be aware of?
rextended
Wed Apr 12, 2023 3:27 pm
It's more efficient to remove all records with one command, rather than deleting each individual record individually,
that's why on my versions remove is outside the :put logging.
For Name
/ip dns static
    :local removethis [find where (name=$iname) and (type=AAAA) and (address!=$newadd)]
    remove $removethis
    :if ([:len [find where (name=$iname) and (type=AAAA) and (address=$newadd)]] = 0) do={
For RegEx
/ip dns static
    :local removethis [find where (regexp=$iregex) and (type=AAAA) and (address!=$newadd)]
    remove $removethis
    :if ([:len [find where (regexp=$iregex) and (type=AAAA) and (address=$newadd)]] = 0) do={
Users browsing this forum: No registered users and 72 guests
