youtube345
Routing Specific Website To LTE
Wed Apr 12, 2023 7:39 pm
lte1 functioning perfectly when i disconnect pppoe-out1. 192.168.88.251 my pc ip.
Here's the specific steps and settings that i did route only specific devices to lte1
Method 1 :
Step 1 : Create new Route table Enable "FIB"
Step 2 : Create new route for lte1
IP --> Routes --> Add New
Dst. Address: 0.0.0.0/0
Gateway: lte1
Routing Table: Select the table created in Step 1
Step 3 : Create route rule(s) for devices or specific traffic to use lte1
IP --> Routes --> Rules --> Add New
For device routing specifiy device IP in Src. Address
Action: lookup only in table
It not working .So i try second method.The same way i successful with my VPN.
Method 2 :
Step 1 : Create Address List
Step 2 : Create Mangle
It not working again. I can't access ipaddress.my to get lte1 IP. (My VPN work fine when i use this method)
youtube345
Re: Routing Specific Website To LTE
Thu Apr 13, 2023 2:19 pm
someone help me please.
youtube345
Sat Apr 15, 2023 8:35 am
Bump
anav
Sat Apr 15, 2023 1:54 pm
Dont think its possible.
spippan
Sat Apr 15, 2023 11:47 pm
for Method 2:
before you add the routing mark, first mark the connection
then add routing mark only to those marked connections
did a similar configuration for a company about a month ago
youtube345
Tue Apr 18, 2023 8:45 pm
for Method 2:
/ip firewall address-list
add address=ping.eu list=TESTVPN
/routing table
add disabled=no fib name="Tables to VPN""
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address-list=TESTVPN new-connection-mark=mc_vpn passthrough=yes
add action=mark-routing chain=prerouting connection-mark=mc_vpn new-routing-mark="Tables to VPN" passthrough=no
add comment=Enable/Disable disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 pref-src=0.0.0.0 routing-table="Tables to VPN" scope=30 suppress-hw-offload=no target-scope=10
It not work even with my VPN.
But when i replace above mangle with this mangle. It work with my VPN (Not LTE)
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=TESTVPN new-routing-mark=Tables to VPN passthrough=no
youtube345
Fri Apr 28, 2023 6:56 am
Bump
youtube345
Wed May 03, 2023 5:12 pm
Bump
Users browsing this forum: No registered users and 84 guests
