RaivisR
LTE18 and CA
Thu Apr 13, 2023 3:32 pm
So I am one of the unhappy users of LHG LTE18 with operator being LMT. Or rather was.
This is about well known trouble with CA channels not being brought up when traffic increases on Quectel EG12/EG18 modems.
And the solution is simple:
/interface/lte at-chat lte1 input="AT+QCFG=\"rrc\",4"
followed by reboot.
I don't know details as to why this is the way it is, either LMT does not support R9 of RRC protocol or there is bug in Quectel's implementation or there is some other miscommunication between UE and eNB, but kicking RRC revision down to R8 solves the problem.
It might help with other Mikrotik's LTE12 and LTE18 devices and other operators having the same issue.
Amm0
Re: LTE18 and CA
Thu Apr 13, 2023 4:20 pm
Interesting. Not in Latvia, but there have been fews posts about this problem...
Seem there is a problem and theory has ranged from signal strengh, MIMO-ness, cell towers power down CA at night, carrier CA logic, and bugs in firmware. See also: viewtopic.php?p=991157&hilit=LMT#p991157
RaivisR
Re: LTE18 and CA
Thu Apr 13, 2023 4:24 pm
I know, I have read all those posts back and forth and have stirred up techies at LMT and at the end after reading about how CA is supposed to work and Qectel AT command manual, I tried kicking down modem's RRC from default R9 to R8 and it started to work as expected.
LHG LTE18 does have only 2 antennas, while EG18 supports 4, which means that under perfect conditions full potential of EG18 will not be used and 1.2Gbps claimed data rate most likely is a lie, but in my case at least having reliable CA band bring-up is sufficient.
evilworm
Re: LTE18 and CA
Thu Apr 13, 2023 4:59 pm
just tested on LMT LTE18, does not seem to work ... I still loose all CA bands in about 20 minutes and they never return... is there something else you might have modified through AT commands?
RaivisR
Re: LTE18 and CA
Thu Apr 13, 2023 5:01 pm
No modifications, try speedtest or similar and see if they come back. Normally CA bands should be brought up only on demand.
evilworm
Re: LTE18 and CA
Thu Apr 13, 2023 5:34 pm
I’ve been having CA issues for a while now and I kind of know when they work and when not :) I did set rrc to 4, rebooted, after 15-20 min CA are gone and downlink usage does not seem to have any effect. Cell monitor also reports only primary band…
Are you 100% sure that changing rrc was the only thing you did? I have a hunch that it might have something to do with CQI reporting back to network and the reported number is lower than tower expects… but this is a wild guess…
RaivisR
Re: LTE18 and CA
Thu Apr 13, 2023 5:42 pm
Absolutely positive it's the only thing. Latest firmware though. Was on the phone with LMT tech and he reassured that even though there are only two antennas, everything gets reported back as it should. Maybe signal levels are just way too low?
evilworm
Re: LTE18 and CA
Thu Apr 13, 2023 7:48 pm
I was trying this on my indoor backup unit... maybe the signal indeed was too weak. I just enabled it on my outdoor Mikrotik ATL LTE18 and it seems that it does not drop CA bands anymore. I mean the bands are persistant even if there is no DL traffic. Looks very good. Will see if CA bands are still there in the morning...
uldis
Re: LTE18 and CA
Thu Apr 13, 2023 7:49 pm
We will to some more tests together with LMT to see what could cause that.
sxtlhglte
Re: LTE18 and CA
Fri Apr 14, 2023 9:25 am
Looks like this "hack" helped LHGG LTE 18
will monitor
Tower is 7.8km away
evilworm
Re: LTE18 and CA
Fri Apr 14, 2023 9:28 am
I can also confirm that this works. Haven’t lost any band during the night.
RaivisR
Re: LTE18 and CA
Fri Apr 14, 2023 10:48 am
I would call this more of a workaround rather than solution though, let the MT and LMT guys do their thing.
One thing that confuses me, is that LTE Rel8/Rel9 supports max 300Mbps DL rate, Quectel EG18 is being advertised as Rel12 device and capable of 1.2Gbps DL rate yet any higher RRC setting than 5 fails with error. Is Quectel lagging behind their promises with firmware?
And major difference between LTE Rel8 and Rel9 in regards of MIMO operation is beam forming at eNB, so maybe under conditions where more or less reliable trialateration of UE is not possible (my specific case and probably most use cases for LHG devices), beam forming fails at eNB and no additional bands can be received at UE? Just thinking aloud.
evilworm
Re: LTE18 and CA
Fri Apr 14, 2023 10:55 am
Got contacted by LMT already to try enabling RRC=5 back, they changed something at the tower. Will try that in an hour and let you know the results…
However this seems to me more quectel related, because you can find similar issues in their forum with different carriers… so this is not something LMT specific…
RaivisR
Re: LTE18 and CA
Fri Apr 14, 2023 11:07 am
Definitely Qeuctel is the one looking shady here (and MT by association a little :) ), not LMT.
editable
Re: LTE18 and CA
Fri Apr 14, 2023 11:31 am
rrc=4 does not work for me.
The strange is that some month ago CA was always connected for weeks, then I got ATL for a test, which also drops CA, now I am connected back to Chateau LTE18 (LMT) with 2 external antennas and now CA drops. Only change I have made is RouterOS upgrade from 7.8 to 7.9rc3, but doubt that it should be connected. Anyway, all hopes on MT + LMT testing. Will change back to rrc=5 for now.
evilworm
Re: LTE18 and CA
Fri Apr 14, 2023 11:34 am
For some reason rrc=4 did not work for me at the beginning. But after several restarts and interface up/downs it suddenly started to work. Not sure why, maybe try unplugging power for a few seconds after setting rrc to 4…
RaivisR
Re: LTE18 and CA
Fri Apr 14, 2023 12:04 pm
Keep in mind, this is not magic pill that will make signal appear where it is not, this merely slightly changes the way CA Bands are managed. If signal levels of other bands are below usable, there will be no CA anyway.
RaivisR
Re: LTE18 and CA
Fri Apr 14, 2023 12:43 pm
Another interesting observation - I am running stress test with rcc=4, 20s DL, 20s delay. It works for few hours, CA bands are brought up and torn down, as they should. Until it doesn't. My primary band is B20@10MHz, which sucks, but that is life. When CA works as expected, I see B1 and B3 signals from the cell I am attached to along with other more distant cells. But when CA stops working, all I see in cell monitor, is B20 signals. Interface disable/enable cures this. Another pointer at Quectel not doing a great job?
evilworm
Re: LTE18 and CA
Fri Apr 14, 2023 2:26 pm
So, I've switched back to rrc=5 as per LMT request and it seems that it's running much more stable now after they changed something on their end. CA bands are released/assigned as needed and I always get full CA capacity when downloading. Will see if this still works in the morning...
RaivisR
Re: LTE18 and CA
Fri Apr 14, 2023 2:38 pm
I also got a call from LMT and apparently EG18 reports Rel12 capabilities to network and all this changing RCC thing most likely is correlative, not causative. The jury is still out what is causing this behavior.
sxtlhglte
Re: LTE18 and CA
Fri Apr 14, 2023 4:05 pm
interesting that this issue from the first time when they louched LTE 18 product, and with LMT only..
With Bite and Tele2 this issue is not so obvious and so bad as with LMT..
also when signal ar good RSRP~~-87dbm (1.5km )and BS is upgraded to Nokia AirScale with the latest Modem FW has not observed so many issue with stuck CA.
Lets wait and see what LMT and MT found ..
Amm0
Re: LTE18 and CA
Fri Apr 14, 2023 4:38 pm
And that's the question out here in California about this one. ;)
RaivisR
Re: LTE18 and CA
Fri Apr 14, 2023 5:48 pm
Here in Latvia the issue is most prominent with LMT, but searching through forums, it's not limited to this one single operator, so that's not it.
For now I left rcc=4, because that seems to run longer AND set up script to reset interface every 3 hours, will see how it works for workaround while real solution is found.
Anyone who have at least attempted to read the LTE and LTE-A specs should be amazed that any of it works at all, spec describing RCC alone is almost 1000 pages :)
editable
Re: LTE18 and CA
Fri Apr 14, 2023 6:11 pm
I gave a try on rcc=4 once more, hard restart, power off.
While it works for half a day, its CA combination is weak. Primary B7, CA only B28, have not seen other bands. Total speed is still respectable ~150Mbps.
Will leave as is and monitor behaviour.
Primary Band	B7@20Mhz earfcn: 2850 phy-cellid: 483
CA Band		B28@10Mhz earfcn: 9360 phy-cellid: 483
editable
Re: LTE18 and CA
Fri Apr 14, 2023 6:44 pm
And CA died...
CA was B28 only, then B20 only and now CA is not connecting at all. Will not restart anything, but assume that rrc=4 is not a workaround, problem is somewhere else.
sxtlhglte
Re: LTE18 and CA
Fri Apr 14, 2023 11:57 pm
for me it still going strong .. yes speed in the evening is not so great but better than with one Band,
With RRC 5, Rel9 setting it didn't happen after 30+ min CA was lost and didn't come back. Waiting for proper fix from LMT.. :)
RaivisR
Re: LTE18 and CA
Sun Apr 16, 2023 8:57 am
based on my observations of EG18 behavior I am waiting on proper fix from MT/Quectel.
sxtlhglte
Re: LTE18 and CA
Mon Apr 17, 2023 3:25 pm
and after 3day PDP context uptime no more CA for me :/
evilworm
Re: LTE18 and CA
Mon Apr 17, 2023 3:31 pm
almost 3 days and CA works as expected... running on rrc=5 after switching back from rrc=4 after LMT request
however it does look like it's running like rrc=4, because CA bands are not dropped when I don't have traffic
evilworm
Re: LTE18 and CA
Tue Apr 18, 2023 9:40 am
after 3 days...
MRSample
Re: LTE18 and CA
Wed Apr 19, 2023 10:40 am
Hi i am from same region where you are based (Vidzeme) hit up my email let's brainstorm about this lte flaw
dzintars999@gmail.com
emilst
Re: LTE18 and CA
Thu Apr 20, 2023 12:16 pm
Hello RaivisR,
Please open a support ticket at our customer support portal:
https://help.mikrotik.com/servicedesk/servicedesk
We would like to get some additional information about your issue.
Regards,
Emīls
uldise
Re: LTE18 and CA
Mon May 01, 2023 4:34 pm
Ten days after last post, and no new info?
RandomguyLel
Re: LTE18 and CA
Mon May 01, 2023 8:49 pm
True, would be nice to know if there is anything new(or some updates) about this issue.
RaivisR
Re: LTE18 and CA
Mon May 08, 2023 8:01 am
They are still trying to figure it out according to support ticket I opened. Meanwhile I got Fibocom CAT6 modem and will try it out as soon as I get a chance to climb up to my LHG on site.
editable
Re: LTE18 and CA
Mon May 08, 2023 8:57 am
With 1 external antenna (RI=1) CA drops, but when using 2 external antennas(RI=2), sometimes it drops only after days, I had a period when it was not dropped for weeks.
editable
Re: LTE18 and CA
Tue Jul 04, 2023 6:05 pm
Any update? Still the same issue.
dimko
Re: LTE18 and CA
Wed Sep 06, 2023 10:44 pm
Same issues with MikroTik Chateau LTE12 RBD53G-5HacD2HnD-TC&EG12-EA too.
Tested with Router OS 7.9.1 ... up to 7.11.2.
Modem firmware EG12EAPAR01A13M4G.
brusec
Re: LTE18 and CA
Thu Oct 26, 2023 6:05 pm
Router OS 7.11.2.
Users browsing this forum: No registered users and 43 guests
