akshark
Unable to update Router OS
Thu Apr 13, 2023 6:07 pm
Hi All,
We have the MicroTik CRS328-4C-20S-4S+RM 20x SFP + 4xSFP+ switch met 4x combo and have set it up and see that we are able to get internet connectivity working and computers connected to the router also have internet.
However, we are having issues when updating the Router, we see an error message which says "ERROR: could not resolve dns name"
# jan/03/1970 02:31:05 by RouterOS 6.48.6
# software id = KUH3-URPS
# model = CRS328-4C-20S-4S+
# serial number = HEsWN
add admin-mac=48:A9:s:x:x:x auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=sfp-sfpplus1 name=vlan4011_uplink1 vlan-id=4011
add interface=sfp-sfpplus2 name=vlan4022_uplink2 vlan-id=4022
add name=WAN
add name=LAN
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool1 disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf interface=combo1
add bridge=bridge comment=defconf interface=combo2
add bridge=bridge comment=defconf interface=combo3
add bridge=bridge comment=defconf interface=combo4
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=sfp2
add bridge=bridge comment=defconf interface=sfp3
add bridge=bridge comment=defconf interface=sfp4
add bridge=bridge comment=defconf interface=sfp5
add bridge=bridge comment=defconf interface=sfp6
add bridge=bridge comment=defconf interface=sfp7
add bridge=bridge comment=defconf interface=sfp8
add bridge=bridge comment=defconf interface=sfp9
add bridge=bridge comment=defconf interface=sfp10
add bridge=bridge comment=defconf interface=sfp11
add bridge=bridge comment=defconf interface=sfp12
add bridge=bridge comment=defconf interface=sfp13
add bridge=bridge comment=defconf interface=sfp14
add bridge=bridge comment=defconf interface=sfp15
add bridge=bridge comment=defconf interface=sfp16
add bridge=bridge comment=defconf interface=sfp17
add bridge=bridge comment=defconf interface=sfp18
add bridge=bridge comment=defconf interface=sfp19
add bridge=bridge comment=defconf interface=sfp20
add interface=sfp1 list=WAN
add interface=sfp2 list=LAN
add interface=sfp3 list=LAN
add interface=sfp4 list=LAN
add interface=sfp5 list=LAN
add interface=sfp6 list=LAN
add interface=sfp7 list=LAN
add interface=sfp8 list=LAN
add interface=sfp9 list=LAN
add interface=sfp10 list=LAN
add interface=sfp11 list=LAN
add interface=sfp12 list=LAN
add interface=sfp13 list=LAN
add interface=sfp14 list=LAN
add interface=sfp15 list=LAN
add interface=sfp16 list=LAN
add interface=sfp17 list=LAN
add interface=sfp18 list=LAN
add interface=sfp19 list=LAN
add interface=sfp20 list=LAN
add interface=combo1 list=LAN
add interface=combo2 list=LAN
add interface=combo3 list=LAN
add interface=combo4 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add address=192.168.88.1/24 comment=defconf interface=sfp2 network=\
    192.168.88.0
add address=192.168.110.42/30 interface=vlan4011_uplink1 network=\
    192.168.110.40
add address=192.168.210.42/30 interface=vlan4022_uplink2 network=\
    192.168.210.40
add address=x.y.z.a/27 interface=combo2 network=x.y.z.b
add address=192.168.88.0/24 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,10.0.0.1
add action=drop chain=input comment="drop ftp brute forcers" dst-port=21 \
    protocol=tcp src-address-list=ftp_blacklist
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 \
    protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
    address-list-timeout=1w3d chain=input connection-state=new dst-port=22 \
    protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
    address-list-timeout=1m chain=input connection-state=new dst-port=22 \
    protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
    protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
    protocol=tcp
add action=masquerade chain=srcnat out-interface=bridge
add distance=1 gateway=192.168.110.41
add distance=1 gateway=192.168.210.41
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system identity
set name=RouterOS
/system routerboard settings
set boot-os=router-os
Any help on what we are missing would be great to know, Thanks.
erlinden
Re: Unable to update Router OS
Thu Apr 13, 2023 6:15 pm
My best guess would be a DNS problem...is this correct (does the MikroTik resolve anything)?
For the time being, you might want to upgrade manually (copy the file upgrade file) and reboot.
Why do you want to upgrade?
Ah...had a second look...your switch is missing a DHCP client on the bridge. Or is missing gateway information. As soon as you add it (and get/have proper IP configuration) you will be able to upgrade.
pe1chl
Thu Apr 13, 2023 7:12 pm
You have this:
Is that 10.0.0.1 a valid DNS resolver that can lookup internet DNS names? If not, remove it. Make it 1.0.0.1 or 1.1.1.1 or 9.9.9.9 or whatever.
akshark
Thu Apr 13, 2023 9:58 pm
Thanks for your reply.
On MicroTik terminal if i execute
ping 8.8.8.8 src-address=x.y.z.65
this works
but
ping google.com src-address=x.y.z.65
does not work.
We do have a gateway configured like below
is the DHCP Client necessary for DNS to work?
akshark
You have this:
Thanks for your reply. ok i will remove it but should 8.8.8.8 not handle DNS?
pe1chl
Thu Apr 13, 2023 10:12 pm
When there is a server 10.0.0.1 that does DNS but not for the internet, the above setup will fail.
There is no "when server 1 says NO let's ask server 2" function in DNS.
akshark
Fri Apr 14, 2023 12:27 am
I just updated the DNS servers to 8.8.8.8 and 8.8.4.4 but i still see the same error "could not resolve DNS name"
anav
Fri Apr 14, 2023 12:33 am
Your router is misbehaving because the admin is confused.
The admin doesnt know whether he has a bridge and what function the bridge has in the config.
What IP address do you give the bridge for example.......
akshark
Fri Apr 14, 2023 12:35 am
its x.y.z.65
anav
Fri Apr 14, 2023 12:40 am
Like I said, you dont have a clue of what you have configged.
192.168.88.0
192.168.110.40
192.168.210.40
There is no bridge address its missing............. the dchp-server identifies a bridge, you have bridge ports too......
Why do you masquerade bridge traffic.........??
akshark
Fri Apr 14, 2023 1:03 am
192.168.88.0
192.168.110.40
192.168.210.40
sorry, I am new to configuring switch / router and learning everyday.
I the quick set config i see the Mode is set to "Bridge" and IP is set to "x.y.z.65". Please see the attached image for your reference.
if you could point me what i am missing it would be great.
Users browsing this forum: No registered users and 35 guests
