Hi all guys, I'm new to Mikrotik but before posting this new topic I've done a lot of searches on the web without find a solution.
I have two VLANs configured under same bridge.
10.0.10.x/24 subnet - VLAN10
10.0.20.x/24 subnet - VLAN20
Using WinBox I've created a firewall rule that allow all the traffic from some VLAN20's IP to all the 10.0.10.x/24.
It works fine, I'm able to reach those IPs from any device under VLAN10. Since I'm a newbie I'm happy for this result!
For a particular device configuration I need to create a 1:1 NAT between 10.0.10.221 to 10.0.20.1.
The final target is: assuming that I'm on 10.0.10.13 IP, I'm able to ping 10.0.10.221 (because the NAT will redirect my ping to 10.0.20.1).
I've tried to configure a "dst nat" but it seem not working.
I've also tried to configure a "dst nat" over "netmap" but it's the same...
I'm a little bit confused... I have a great knowledge and great skills on NAT configuration over many other brand devices like Fortinet, Sonicwall, Zyxel, Altaro, Ubiquiti Unify,... but here I need your help.
May I ask for your suggestion on how I can configure this simple kind of NAT?
Many thanks in advance.
Bye!
