Specimen
Bridge Bonded SFP+ with vlans
Fri Apr 14, 2023 7:31 pm
Hello, i need help with this easy task, but its confusing me cause it refuses to work.
Can someone help me what am i doing wrong, because my head is exploding.
First of all, should i be able to discover router while im connected with router via sfp+? I dont see nothing, until im connecting with copper.
Connecting to the router, removing default configuration, reconnecting using mac address.
Creating bonding interface, selecting my sfp2 and sfp3 ports, mode - rr
Creating bridge, setting admin mac (mac address of a created new bridge)
Adding my created in a prev.step bonding interface port to the bridge, setting up a ip to the bridge
(Example 10.0.0.1/24)
Creating vlans on a bridge interface (should i use bridge or bond interface?), setting up id's, and setting ip addresses for them.
In a bridge - vlans im tagging my bridge, sfp2, sfp3 ( should i tag bonding?) (I only need tagged trunks, dont need untagged ones). Activating bridge vlan filtering and nothing is working, im getting disconnected just only im getting my sfp interface enabled.
Where is the problem? Did i misconfigured something?
Would you be kind to export "correct config" for what i just tried to describe with my bad english :( thank you! P.s routeros 7.8
Users browsing this forum: AdamT77, mszru, pturmel and 134 guests
