Techsystem
restore a password from a backup file
Sat Apr 15, 2023 3:01 pm
Hello My friends..!
so is there is a way that i can retore the password from a backup file..?
i want to restore a specific backup from a year in my RB2011 router, but i forget the login pass..?
mkx
Re: restore a password from a backup file
Sat Apr 15, 2023 8:49 pm
There are two problems:
  1. you need access to device. So either you have to know current password or you have to wipe whole config
  2. it's only possible to restore full config from backup, you can't "cherry-pick" only specific bits
rextended
Sat Apr 15, 2023 9:24 pm
If the backup is old enough, like 6.1x, the password is saved basically as clear text (just an XOR...)
If the backup is of a newer version, the hash with other encryption is saved, so it is impossible to get back the plaintext password without using "brute force"...
The recovery of the access passwords of the RouterBOARD is deliberately almost impossible (without brute force or similar), they are not even in the export.
optio
Long time Member
Long time Member
Sun Apr 16, 2023 2:48 pm
Try with this if you have older ROS version: https://github.com/BigNerd95/RouterOS-Backup-Tools
rextended
Sun Apr 16, 2023 11:44 pm
Warning
User password format
ROS v6.45.1+ removed insecure password storage, so they cannot be extracted with extract_user.py any more.
Users browsing this forum: GoogleOther [Bot], jaclaz and 111 guests
