Thu Aug 17, 2023 11:51 am
Hi, thanks for the reply.
I have been using Mikrotik for years in SMB and also personally and I am fascinated with it from the start. Great work!
Now I have a small problem which is driving me nuts, on one HAP lite device which I use for monitoring network resources and using simple Netwatch scripts to send webhooks to Teams is not working.
This has been working for years and it stopped all of u sudden not sure why?
I am using RouterOS 6.49.8 on a RB951-2HnD, this is how I have the script set. The webhooks from other services is working on that particular Teams channel, so only from 2 different Mikrotik’s it is not.
Sending to Telegram works without any issues.
In the attach you can see the script itself.
Please let me know what could be the issue if you have any ideas?
