The config export is here: viewtopic.php?t=195365 (Fixed Fiber configuration (uplink to ISP cpe)).
Code: Select all
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc pfs-group=modp2048
Code: Select all
10:41:08 l2tp,ppp,info l2tp-to-bbone0: initializing...
10:41:08 l2tp,ppp,info l2tp-to-bbone0: connecting...
10:41:08 l2tp,ppp,info l2tp-to-bbone0: terminating... - tunnel was not encrypted
10:41:08 l2tp,ppp,info l2tp-to-bbone0: disconnected
10:41:10 ipsec,error initiator can't find identity for peer: l2tp-to-bbone0
10:41:18 l2tp,ppp,info l2tp-to-bbone0: initializing...
10:41:18 l2tp,ppp,info l2tp-to-bbone0: connecting...
10:41:18 l2tp,ppp,info l2tp-to-bbone0: terminating... - tunnel was not encrypted
10:41:18 l2tp,ppp,info l2tp-to-bbone0: disconnected
10:41:20 ipsec,error initiator can't find identity for peer: l2tp-to-bbone0
10:41:24 system,info peer proposal default changed by chrisckr
10:41:24 ipsec,error initiator can't find identity for peer: l2tp-to-bbone0
10:41:28 l2tp,ppp,info l2tp-to-bbone0: initializing...
10:41:28 l2tp,ppp,info l2tp-to-bbone0: connecting...
10:41:28 l2tp,ppp,info l2tp-to-bbone0: terminating... - tunnel was not encrypted
10:41:28 l2tp,ppp,info l2tp-to-bbone0: disconnected
10:41:34 ipsec,error initiator can't find identity for peer: l2tp-to-bbone0
10:41:38 l2tp,ppp,info l2tp-to-bbone0: initializing...
10:41:38 l2tp,ppp,info l2tp-to-bbone0: connecting...
10:41:38 l2tp,ppp,info l2tp-to-bbone0: terminating... - tunnel was not encrypted
10:41:38 l2tp,ppp,info l2tp-to-bbone0: disconnected
10:41:44 ipsec,error initiator can't find identity for peer: l2tp-to-bbone0
10:41:48 l2tp,ppp,info l2tp-to-bbone0: initializing...
10:41:48 l2tp,ppp,info l2tp-to-bbone0: connecting...
10:41:48 l2tp,ppp,info l2tp-to-bbone0: terminating... - tunnel was not encrypted
10:41:48 l2tp,ppp,info l2tp-to-bbone0: disconnected
After removing dynamic peer.
Code: Select all
10:41:58 l2tp,ppp,info l2tp-to-bbone0: initializing...
10:41:58 l2tp,ppp,info l2tp-to-bbone0: connecting...
10:42:01 ipsec,info initiate new phase 1 (Identity Protection): 192.168.2.10[500]<=>213.7.231.xx[500]
10:42:02 ipsec,info ISAKMP-SA established 192.168.2.10[4500]-213.7.231.xx[4500] spi:d2a3ae6a0321f87a:0a3be58ddd70f81b
10:42:05 l2tp,ppp,info l2tp-to-bbone0: authenticated
10:42:05 l2tp,ppp,info l2tp-to-bbone0: connected
