davesmith
IPv4 Routes supported by CCR1072-1G-8S+
Wed Apr 19, 2023 3:55 pm
I have been searching within the forums and I have read - https://wiki.mikrotik.com/wiki/Manual:B ... e_table.3F - in order to find out how many how many IPV4 routes can CCR1072-1G-8S+ hold?. I saw here - viewtopic.php?t=132903 - that someone said that their 1072 supports 2 million routes and it handles it without a problem. I comparing it with a Juniper MX5 router and I need CCR1072-1G-8S+ to use 3 ISP, all of them announcing full (or close to full) routing tables.
mada3k
Long time Member
Long time Member
Re: IPv4 Routes supported by CCR1072-1G-8S+
Sat Apr 22, 2023 10:19 pm
The 1072 is quite old. Would not recommend it. All CCR10xx only does software routing, hence there is no real upper limit (except for memory) CCR2116 is a better choice.
However, No Mikrotiks can hold million of routes in hardware. Not sure what a MX5 does but probably more, since a couple of factors more expensive.
rextended
Sun Apr 23, 2023 1:23 am
Approximately each entry occupies 512bytes.
For about 1,000,000 routes, roughly the size of the Full Route Table now, you need roughly 512Mbytes per table.
With 3 different BGPs, that's roughly 1536MB of memory used.
The CCR1036-12G-4S, that have 4GB of RAM, does it perfectly without problems (it only acts as an Edge Router)
Users browsing this forum: MartinsG, mseidler, Ramirocuei and 103 guests
