nevaran
hAP AX2 storage space and containers
Sat Apr 22, 2023 2:16 pm
I just got my first mikrotik router after being impressed by an old model at my workplace and noticed it had container capability;
But for some reason even though I noticed it having a USB light indicator- theres no actual USB port?
I tried installing a container for ad blocking - adguard was the last one I saw since it looked like small size, but even that one does not want to extract because of too little space in the router.
My question is if theres any way to pull packages onto the RAM memory instead of storage and installing it from there to see if it will work- or have an external storage device thats connected by the Ethernet port or *something* that will allow me to install useful containers?
If there isnt; what containers can I actually put in there without needing more than 90MB space?
holvoetn
Re: hAP AX2 storage space and containers
Wed Apr 26, 2023 9:38 pm
You may have some luck ...
Using Rose-storage package it should be possible to use some RAM as ramdisk.
https://help.mikrotik.com/docs/display/ ... ge-RAMdisk
And then you should be able to store containers there.
Be aware though, for now the pulling part of the container-setup is on flash.
Second remark: ramdisk means: reboot = everything gone.
It is indeed a pity there was no USB port added to AX2.
nevaran
Thu Apr 27, 2023 4:42 pm
I already managed to do that but that means, like you said, I will have to never turn the router off or ill have to just reinstall everything again; Turns out even adguard home container uses at least 140-190Mb; which is well over the storage space of the router, sadly;
Is there any way to use an ethernet port as extended storage? Or should I just be looking at a dedicated machine for such containers
holvoetn
Thu Apr 27, 2023 4:47 pm
Same Rose-storage package should allow this.
NFS or SMB
nevaran
Sat Apr 29, 2023 7:43 am
NFS or SMB
Alright SMB sounds perfect- any documentation on how to do it properly?
holvoetn
Sat Apr 29, 2023 11:00 am
nevaran
Sat Apr 29, 2023 2:32 pm
I did try that but I cant seem to make it work.
Can it not have password protection on the SMB path?
Amm0
Sat Apr 29, 2023 5:21 pm
The docs could be improved for sure...they do mention the parameters but have no description.
But add a "smb-password=".
If you hit <tab> at the CLI it will show all the options to commands, include ROSE.
nevaran
Sat Apr 29, 2023 5:53 pm
Oh I see- and what is the smb-share? the location on the device?
I also see an smb-encryption command though im not sure what to write on that one either
Amm0
Sat Apr 29, 2023 7:30 pm
I’m not sure it needs to be set. But if you hit <tab> after equal sign smb-encryption=<tab> it will show the options. But I’ve never set it. the smb-share= is the SMB name.
nevaran
Sat Apr 29, 2023 8:53 pm
What is the smb name supposed to be?
Amm0
Sat Apr 29, 2023 9:23 pm
Well, it's the share name you're using on the other end. If both ends are Mikrotik, the smb-share= is the client, but it be same as the smb-export= set on the ROS ROSE server-side. If the SMB share is from windows/NAS its the part after the the single slash e.g. smb-share=myshare smb-if the SMB path was \\mycomputer\myshare (with smb-address= ideally the IP address of of "mycomputer" in this example).
nevaran
Sun Apr 30, 2023 3:20 pm
Yeah so i did try it correctly but it didnt seem to work...weird.
Ill just wait until I get a new tik with a USB lol
Amm0
Sun Apr 30, 2023 6:16 pm
I've used NFS between two Mikrotik for containers and that's worked perfectly.
ROSE SMB does seem a little more finicky. SMB only works in latest stable to a MacOS. I've never tested it to actual Windows share, but perhaps the smb-encryption needs to be sent. But if the other end is a NAS box, I'd recommend trying NFS instead.
Amm0
Sun Apr 30, 2023 6:18 pm
And, yes, it's disappointing that the hAPax2 doesn't have a USB port. It's predecessor hAPac2 had one...
nevaran
Sun Apr 30, 2023 6:19 pm
Nope, its a windows installation that I use for multiple stuff including file sharing over the network.
I was going to go for a linux install as a server to replace it so it can run containers on that instead, but theres neither the time nor the experience with linux for me to do that yet.
Either way im still a bit mad that the ax2 didnt come with a USB
Amm0
Sun Apr 30, 2023 6:27 pm
Maybe someone else has an idea on ROS SMB to Windows... It really should work, or at least a bug.
nevaran
Sun Apr 30, 2023 7:55 pm
When i tried it it just made a folder path in the router's storage using the path i did, without the start double \ - it just made a single one there. Im not sure if im doing something wrong or what
Amm0
Mon May 01, 2023 12:49 am
I tested this myself since I was curious about Windows and ROSE SMB. I got it to work. I had to use a use a local user (with permissions to the share), with all the options below...
/disk/add smb-share=temp smb-address=192.168.123.123 type=smb smb-user=mikrotik smb-password=forum slot=winsmb smb-encryption=yes
nevaran
Mon May 01, 2023 8:42 am
Yup did pretty much the same, the "temp" was "F/dns" folders for me- i didnt do slot=winsmb since im not sure what it does. Could be the reason?
nevaran
Mon May 01, 2023 10:34 am
I used slot=winsmb this time and it did seem to work out but when installing/downloading the container, it ended up with this error:
https://i.imgur.com/ZgXCfIF.png
nevaran
Mon May 01, 2023 6:40 pm
Turns out its becuase its not ext3/ext4, it will error out;
Making a flash drive and formatting it into ext4 and plugging it into the windows machine, it can share the drive; but then the disk mounting doesnt seem to work on the MK; at least not with slot=winsmb
Not sure where to go from there
Amm0
Mon May 01, 2023 8:13 pm
I didn't test the SMB share with a container. But I'm not sure the file system matters since it's abstracted by SMB, but would have to be readable on the Windows side.
Not discounting a bug in ROSE, and not expert in modern Windows, but not sure Windows support sharing a ext4 disk (but maybe?). But any reason to not just create the share from a real disk on Windows PC/server for the container? You can always move the container to a USB stick when you get a Mikrotik that has one ;)
nevaran
Mon May 01, 2023 9:44 pm
Windows doesnt support ext3/4 , so the container on the MK cannot actually be installed. I was thinking of just reinstalling my windows server to a linux (debian) one, but since im much much much less familiar with linux systems- that idea is put on the side for now...
Also while windows cannot read the ext4 USB i had tried to plug, it was still possible to share the drive somehow; even though it didnt seem to want to open nor to get mounted on the mikrotik, which is a shame.
Users browsing this forum: No registered users and 1 guest
