İmposss
Hap ac2 2x2mimo bad bandwidth
Sat Apr 22, 2023 4:17 pm
Hello, I am using two Mikrotik Hapac2 at my home. My internet speed has increased and a problem has emerged. While there is no problem with 1x1 devices at both close and far distances, computers with 2x2 Intel chipset adapter cards (I couldn't try other brands) become unusable at far distances, it is unable to exceed 20 mbps, and even disconnects frequently. While a 1x1 phone can see 65 mbps at the same distance, a 2x2 computer cannot exceed 20 mbps. A cheap router provided by the ISP can reach 50 mbps on the phone and 95 mbps on the computer at the same distance. I would be happy if someone who has encountered this problem and found a solution could share it with me. Thanks.
tested phones: lg g6, samsung s10, iphone
tested laptops: lenovo thinkbook (ax201), hp elitebook 840 (ax201), lenovo y580 (intel ac7260)
tested frequency: 5GHz
  MikroTik RouterOS 7.8 (c) 1999-2023       https://www.mikrotik.com/
Press F1 for help
[Apo@hAP ac2] > export hide
# apr/22/2023 16:07:44 by RouterOS 7.8
# software id = xxx
# model = RBD52G-5HacD2HnD
# serial number = xxx
/caps-man channel
add band=5ghz-n/ac extension-channel=Ceee frequency=5180 name="5 GHz " skip-dfs-channels=yes tx-power=20
add band=2ghz-g/n extension-channel=Ce frequency=2412,2452 name="2.4 GHz" tx-power=13
/caps-man datapath
add client-to-client-forwarding=yes local-forwarding=yes name="local forward"
add admin-mac=xxx arp=reply-only auto-mac=no name="Local Bridge"
add admin-mac=xxx auto-mac=no name="PPPoE Bridge"
/interface vlan
add interface="PPPoE Bridge" name="PPPoE vlan35" vlan-id=35
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface="PPPoE vlan35" keepalive-timeout=60 name=PPPoE user=xxx
/caps-man rates
add name="Rate 2.4GHz"
add name="Rate 5GHz"
/caps-man security
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm group-encryption=aes-ccm name=Apo
/caps-man configuration
add datapath.local-forwarding=yes hw-protection-mode=rts-cts mode=ap name=Apo security=Apo ssid=Apo
add channel="2.4 GHz" country=turkey datapath="local forward" hw-protection-mode=rts-cts mode=ap name="Apo 2.4GHz" rates="Rate 2.4GHz" \
add channel="5 GHz " country="united states" datapath="local forward" hw-protection-mode=rts-cts mode=ap name="Apo 5GHz" rates="Rate 5GHz" \
add channel="2.4 GHz" country=turkey datapath="local forward" hw-protection-mode=rts-cts mode=ap name="slave Apo 2.4GHz" rates="Rate 2.4GHz" \
    security=Apo ssid="Apo 2.4GHz"
add channel="5 GHz " country="united states" datapath="local forward" hw-protection-mode=rts-cts mode=ap name="slave Apo 5 GHz" rates=\
    "Rate 5GHz" security=Apo ssid="Apo 5GHz"
add name=WAN
add name=LAN
/interface lte apn
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=Apo supplicant-identity=""
/interface wireless
# managed by CAPsMAN
# channel: 2412/20-Ce/gn(10dBm), SSID: Apo, local forwarding
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-g/n channel-width=20/40mhz-XX country=no_country_set \
    disabled=no frequency=auto frequency-mode=manual-txpower guard-interval=long hw-protection-mode=rts-cts mode=ap-bridge name="wlan 2.4GHz" \
    security-profile=Apo ssid=Apo tx-power-mode=all-rates-fixed wmm-support=enabled wps-mode=disabled
# channel: 5180/20-Ceee/ac(17dBm), SSID: Apo, local forwarding
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-n/ac channel-width=20/40/80mhz-XXXX country=\
    no_country_set disabled=no frequency=auto frequency-mode=manual-txpower guard-interval=long hw-protection-mode=rts-cts mode=ap-bridge \
    name="wlan 5GHz" security-profile=Apo skip-dfs-channels=all ssid=Apo tx-power-mode=all-rates-fixed wmm-support=enabled wps-mode=disabled
add name=DHCP ranges=192.168.8.100-192.168.8.254
add add-arp=yes address-pool=DHCP interface="Local Bridge" name="Local DHCP"
/ppp profile
set *0 change-tcp-mss=default use-ipv6=default
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
add disabled=no name=default-v3 version=3
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add disabled=yes instance=default-v3 name=backbone-v3
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface="Local Bridge"
/caps-man provisioning
add action=create-dynamic-enabled disabled=yes master-configuration=Apo name-format=identity
add action=create-dynamic-enabled hw-supported-modes=gn,g,b master-configuration="Apo 2.4GHz" name-format=prefix-identity name-prefix=\
    "Wlan 2.4GHz" slave-configurations="slave Apo 2.4GHz"
add action=create-dynamic-enabled hw-supported-modes=ac,an,a master-configuration="Apo 5GHz" name-format=prefix-identity name-prefix=\
    "Wlan 5GHz" slave-configurations="slave Apo 5 GHz"
add bridge="Local Bridge" ingress-filtering=no interface=ether2
add bridge="Local Bridge" ingress-filtering=no interface=ether3
add bridge="Local Bridge" ingress-filtering=no interface=ether4
add bridge="Local Bridge" ingress-filtering=no interface=ether5
add bridge="PPPoE Bridge" interface=ether1
/ip settings
set accept-source-route=yes max-neighbor-entries=8192
/ipv6 settings
set max-neighbor-entries=8192
add interface="Local Bridge" list=LAN
add interface=PPPoE list=WAN
add interface=ether1 list=WAN
add interface="PPPoE vlan35" list=WAN
add interface="PPPoE Bridge" list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireless cap
set bridge="Local Bridge" discovery-interfaces="Local Bridge" enabled=yes interfaces="wlan 5GHz,wlan 2.4GHz"
add address=192.168.8.59/24 interface="Local Bridge" network=192.168.8.0
/ip dhcp-client
add add-default-route=no dhcp-options=clientid disabled=yes interface="PPPoE Bridge" use-peer-dns=no use-peer-ntp=no
/ip dhcp-server config
set store-leases-disk=immediately
add address=192.168.8.0/24 dns-server=192.168.8.59,192.168.8.49 gateway=192.168.8.59 ntp-server=162.159.200.123
set allow-remote-requests=yes cache-max-ttl=1d use-doh-server=https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=2606:4700:4700::1001 name=cloudflare-dns.com type=AAAA
add address=2606:4700:4700::1111 name=cloudflare-dns.com type=AAAA
add address=1.0.0.1 name=cloudflare-dns.com
add address=1.1.1.1 name=cloudflare-dns.com
add address=104.16.248.249 name=cloudflare-dns.com
add address=104.16.249.249 name=cloudflare-dns.com
add address=192.168.8.59 name=ApoDNS1
add address=fe80::c6ad:34ff:fe01:4059 name=ApoDNS1 type=AAAA
/ip firewall address-list
add address=0.0.0.0/8 comment="defconf: RFC6890" list=no_forward_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=no_forward_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890 multicast" disabled=yes list=no_forward_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" disabled=yes list=no_forward_ipv4
add address=127.0.0.0/8 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890 multicast" disabled=yes list=bad_dst_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6890 reserved" disabled=yes list=bad_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6890 reserved" list=not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add action=accept chain=input comment="defconf: accept ICMP after RAW" protocol=icmp
add action=accept chain=input comment=capsman dst-address-type=local protocol=udp src-address-type=local src-port=5246,5247
add action=accept chain=input comment=capsman dst-address-type=local dst-port=5246,5247 protocol=udp src-address-type=local
add action=accept chain=forward comment="defconf: accept all that matches IPSec policy" ipsec-policy=in,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
    in-interface-list=WAN
add action=drop chain=forward comment="defconf: drop bad forward IPs" src-address-list=no_forward_ipv4
add action=drop chain=forward comment="defconf: drop bad forward IPs" dst-address-list=no_forward_ipv4
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu passthrough=yes protocol=tcp tcp-flags=syn
add action=accept chain=srcnat comment="defconf: accept all that matches IPSec policy" disabled=yes ipsec-policy=out,ipsec
add action=masquerade chain=srcnat out-interface=PPPoE
/ip firewall raw
add action=accept chain=prerouting comment="defconf: enable for transparent firewall" disabled=yes
add action=accept chain=prerouting comment="defconf: accept DHCP discover" dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN \
    protocol=udp src-address=0.0.0.0 src-port=68
add action=accept chain=prerouting comment=capsman dst-address-type=local dst-port=5246,5247 protocol=udp src-address-type=local
add action=accept chain=prerouting comment=capsman dst-address-type=local protocol=udp src-address-type=local src-port=5246,5247
add action=drop chain=prerouting comment="defconf: drop echo request from wan" icmp-options=8:0-255 in-interface-list=WAN protocol=icmp
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment="defconf: drop forward to local lan from WAN" dst-address=192.168.8.0/24 in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop local if not from default IP range" in-interface-list=LAN src-address=!192.168.8.0/24
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 protocol=udp
add action=drop chain=prerouting comment="defconf: drop bad tcp" port=0 protocol=tcp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" disabled=yes jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" disabled=yes jump-target=bad_tcp protocol=tcp
add action=accept chain=prerouting comment="defconf: accept everything else from LAN" in-interface-list=LAN
add action=accept chain=prerouting comment="defconf: accept everything else from WAN" in-interface-list=WAN
add action=accept chain=prerouting comment="defconf: drop the rest"
/ip firewall service-port
set rtsp disabled=no
/ip service
set www-ssl disabled=no
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=PPPoE type=external
add interface="Local Bridge" type=internal
/ipv6 address
add address=::c6ad:34ff:fe01:4059 eui-64=yes from-pool=ipv6 interface="Local Bridge"
/ipv6 dhcp-client
add interface=PPPoE pool-name=ipv6 request=prefix use-peer-dns=no
/ipv6 firewall address-list
add address=fe80::/10 comment="defconf: RFC6890 Linked-Scoped Unicast" disabled=yes list=no_forward_ipv6
add address=ff00::/8 comment="defconf: multicast" disabled=yes list=no_forward_ipv6
add address=::1/128 comment="defconf: RFC6890 lo" list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: RFC6890 IPv4 mapped" list=bad_ipv6
add address=2001::/23 comment="defconf: RFC6890" list=bad_ipv6
add address=2001:db8::/32 comment="defconf: RFC6890 documentation" list=bad_ipv6
add address=2001:10::/28 comment="defconf: RFC6890 orchid" list=bad_ipv6
add address=100::/64 comment="defconf: RFC6890 Discard-only" list=not_global_ipv6
add address=2001::/32 comment="defconf: RFC6890 TEREDO" list=not_global_ipv6
add address=2001:2::/48 comment="defconf: RFC6890 Benchmark" list=not_global_ipv6
add address=fc00::/7 comment="defconf: RFC6890 Unique-Local" list=not_global_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_dst_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_src_ipv6
add address=ff00::/8 comment="defconf: multicast" list=bad_src_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6 after RAW" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/16
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept IPSec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept IPSec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop bad forward IPs" disabled=yes src-address-list=no_forward_ipv6
add action=drop chain=forward comment="defconf: drop bad forward IPs" disabled=yes dst-address-list=no_forward_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" disabled=yes hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6 after RAW" disabled=yes protocol=icmpv6
add action=accept chain=forward comment="defconf: accept HIP" disabled=yes protocol=139
add action=accept chain=forward comment="defconf: accept IKE" disabled=yes dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept AH" disabled=yes protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ESP" disabled=yes protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches IPSec policy" disabled=yes ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" disabled=yes in-interface-list=!LAN
/ipv6 firewall mangle
/ipv6 firewall raw
add action=accept chain=prerouting comment="defconf: RFC4291, section 2.7.1" dst-address=ff02::1:ff00:0/104 icmp-options=135 protocol=icmpv6 \
    src-address=::/128
add action=drop chain=prerouting comment="defconf: drop echo request from wan" icmp-options=128:0-255 in-interface-list=WAN protocol=icmpv6
add action=drop chain=prerouting comment="defconf: drop bogon IP's" src-address-list=bad_ipv6
add action=drop chain=prerouting comment="defconf: drop bogon IP's" dst-address-list=bad_ipv6
add action=drop chain=prerouting comment="defconf: drop packets with bad SRC ipv6" src-address-list=bad_src_ipv6
add action=drop chain=prerouting comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_dst_ipv6
add action=drop chain=prerouting comment="defconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv6
add action=jump chain=prerouting comment="defconf: jump to ICMPv6 chain" disabled=yes jump-target=icmp6 protocol=icmpv6
add action=accept chain=prerouting comment="defconf: accept local multicast scope" dst-address=ff02::/16
add action=accept chain=prerouting comment="defconf: accept site multicast scope" dst-address=ff05::/16
add action=drop chain=prerouting comment="defconf: drop other multicast destinations" dst-address=ff00::/8
/ipv6 nd
set [ find default=yes ] dns=fe80::c6ad:34ff:fe01:4059,fe80::4a8f:5aff:feef:d049 interface="Local Bridge"
/system clock
set time-zone-name=Europe/Istanbul
/system identity
set name="hAP ac2"
/system logging
add disabled=yes topics=dhcp,debug
add topics=caps
/system ntp client
set enabled=yes
/system ntp client servers
add address=2606:4700:f1::123
add address=162.159.200.123
/system routerboard reset-button
set enabled=yes hold-time=0s..5s on-event="system shutdown"
/system script
add dont-require-permissions=no name="cap on off" owner=Apo policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":lo\
    g info message=(\"mode button was pressed\");\r\
    \n:local i\r\
    \n\r\
    \n:if ([/int wir cap get enabled] = true) do={\r\
    \n  /interface wireless cap set enabled=no;\r\
    \n  :global SlackMessage \"Mode button was presssed. CAP is now disabled.\";\r\
    \n  :if ( [/int wir get 0 disabled ] = false ) do={\r\
    \n    :foreach i in= [ /int wir find ] do={ :int wir disable \$i };\r\
    \n  }\r\
    \n} else={\r\
    \n  /interface wireless cap set enabled=yes\r\
    \n  :global SlackMessage \"Mode button was presssed. CAP is now enabled.\";\r\
    \n}\r\
    \n/system script run message2slack"
/tool sniffer
set filter-interface=PPPoE filter-ipv6-address=2a00:1450:4017:80f::200e/128
[Apo@hAP ac2] >
Users browsing this forum: Amazon [Bot], Google [Bot] and 28 guests
