doychevg
CapsMAN wifiwave2 ?
Sun Apr 23, 2023 8:43 pm
Hello guys,
Since I'm not into using Terminal for configuration is there any upcoming news or something about CaspMAN with WifiWave2 compatibility like an interface and not via Terminal? Since I don't see any point of using AX models with installed wifiwave2 by default and not using CapsMAN between the devices. Otherwise, I don't see how to configure two devices that are using Wifiwave2 doing the job that capsman is doing.
holvoetn
Re: CapsMAN wifiwave2 ?
Sun Apr 23, 2023 9:03 pm
It works via winbox, if that's what you are aiming at.
doychevg
Sun Apr 23, 2023 9:27 pm
I don't know what you are aiming here with this statement but CapsMan is not showing when there is wifiwave2 installed (currently on ac3). As I am aware CapsMan can only be configured via Terminal when wifiwave2 is installed and cannot be via user interface. So that's what I am asking here if somebody knows if there is an upcoming capsman user interface for wifiwave2.
holvoetn
Sun Apr 23, 2023 9:31 pm
You are very wrong.
Capsman v2 can be configured perfectly via winbox.
Sure wifiwave2 is installed ? It is a separate package to be installed on AC3 ( I've done it enough)
What ros version are you using ?
mkx
Sun Apr 23, 2023 9:53 pm
Yep, it's there. Both in WinBox and WebFig: Wireless -> Remote CAP -> CAPsMAN (I'm running v7.8 on Audience and WinBox 3.35).
And yes, it's pretey well hidden. Compared to v6 and legacy CAPsMAN, which was present in top level of sub menus (right below Quick Set and above Interfaces ... ROS v6.49.7 and same WinBox)
holvoetn
Sun Apr 23, 2023 10:14 pm
It's in the same menu structure as wifi wave 2.
Kaldek
Mon Apr 24, 2023 11:34 am
CAPsMANv2 no longer has its own top level menu and it's just under Wireless. To set up a CAPs Manager you go Wireless->Remote CAP->CAPsMAN.
After that you really need to read the help page on WiFi Wave2, and also keep up to date on the 7.9rc release notes.
Users browsing this forum: No registered users and 28 guests
