Pollux33
WLAN -> LAN Bridge no DHCP
Mon Apr 24, 2023 2:07 pm
Dear Guru's,
Hope I'm making an obvious mistake here.
I need to connect two printers to the existing network (192.168.0.0/24).
There is no wired connection present in that area but we do have wifi via an existing Ruckuss Wifi system.
Purchased an mAP with the idea to bridge the wifi network to the two LAN ports which would connect the printers.
Issues encountered:
DHCP is not working when connecting on the LAN Ports
Connecting from the mAP LAN ports works when assigning a static IP f.e 192.168.0.215 but I cannot ping the device from the main network.
Tried to setup relay dhcp to solve the DHCP issue, but no joy.
========Edit and solution=======
Ruckuss has a feature which prevents this kind of dhcp traffic flow. You can disable it in the AP with ssh with this command:
set qos directedDHCP disable
Works like a charm after that
Steps taken:
  • Upgraded to the latest RouterOS 7.8
  • Quick Set
  • CPE
  • Connected to WLAN -> works (Mode station-pseudobridge)
  • Selected Bridge mode
  • Address automatic -> Source WLAN
  • Check-> Bridge All LAN Ports
The config:
# apr/24/2023 12:37:53 by RouterOS 7.8
# software id = 0BFC-XIN7
# model = RBmAP2nD
# serial number = DE4F0FDXXXXX
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=station-pseudobridge ssid=WT
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=\
    tkip,aes-ccm
/ip hotspot profile
/interface bridge filter
add action=drop chain=input dst-port=68 in-interface=!wlan1 ip-protocol=udp mac-protocol=ip
add bridge=bridge1 interface=wlan1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
add interface=ether2 list=LAN
/interface ovpn-server server
set auth=sha1,md5
/ip dhcp-client
add interface=bridge1
/system clock
set time-zone-name=Europe/Amsterdam
Users browsing this forum: GoogleOther [Bot], McSee, Pilo2710 and 59 guests
