Krisken
Bug found? LTAP + ROS 7.8 + GPS issue
Tue Apr 25, 2023 12:54 am
I'm afraid ROS 7.8 broke my GPS. I have an LTAP LTE which worked on ROS 6.x. This was going very well, until this weekend I decided to upgrade to ROS 7.8.
Since then my script no longer sends coordinates to my server. Nor do I get to see the GPS coordinates in Winbox.
Apart from the update, nothing has changed on the device. The GPS antenna is an external magnet antenna that has always worked fine and should definitely get a GPS lock at the moment.
Can someone please help me with this issue?
[admin@ON3KDR/M] /system/console> /port/print
Columns: NAME, CHANNELS, USED BY, BAUD RATE
# NAME CHANNELS USED BY BAUD RATE
0 serial0 1 GPS auto
1 gps 1 115200
2 usb3 1 9600
[admin@ON3KDR/M] /system/gps> export
# Apr/21/2023 00:59:42 by RouterOS 7.8
# software id = FFGV-E8L3
# model = RBLtAP-2HnD
# serial number = D7290C74C2DD
/systemgps
set coordinate-format=dd enabled=yes gps-antenna-select=external port=serial0
[admin@ON3KDR/M] /system/gps> print
enabled: yes
port: serial0
channels: 0
init string:
set-system-time: no
coordinate format: dd
gps-antenna-select: external
[admin@ON3KDR/M] /system/gps> monitor
date-and-time: Apr/20/2023 22:42:06
latitude: none
longitude: none
altitude: none
speed: none
destination-bearing: none
true-bearing: none
magnetic-bearing: none
valid: no
satellites: 0
fix quality: 0
data age: never
Users browsing this forum: Amazon [Bot], askarot, Bing [Bot], Google [Bot], jaclaz and 223 guests
