tenner
ROS NTFS file system support
Tue Apr 25, 2023 1:38 am
Looks like I can format USB disk drives as EXT4 or FAT32 in Router OS. Ideally, I'd like to have a drive that works with Windows and also supports files > 4GB which is not the case for FAT32. Are there any plans for NTFS support in future ROS versions?
ps: I guess I could mount an EXT4 drive under WSL2 in Windows, but would prefer NTFS for simplicity.
mfrommel
Re: ROS NTFS file system support
Tue Apr 25, 2023 9:16 am
It is probably way easier to read ext4 filesystems from Windows than to implement another filesystem into a small divice.
https://superuser.com/questions/37512/h ... on-windows
memelchenkov
Tue Apr 25, 2023 11:16 am
Replace FAT32 with exFAT then. FAT32 is outdated in all senses. NTFS is proprietary, so Linux implementation is rather buggy and only via FUSE. exFAT is not proprietary, and is in Kernel now (new driver since 5.7).
tenner
Sat Apr 29, 2023 7:08 pm
Agreed! Fat32 was introduced in 1996, can we get a Windows supported filesystem that is from this millennia?
Users browsing this forum: GoogleOther [Bot], hasmidzul, Syn, techcomtecnico and 56 guests
