snowl
HTTP websites are returning RouterOS
Tue Apr 25, 2023 5:20 am
Hi all
I've been trying to install Ubuntu Server on a little home NUC for home use except it's been failing to connect to the mirror server. I investigated this and noticed _any_ http address returns the RouterOS page instead of the actual website.
I did a nslookup on au.archive.ubuntu.org and it seems to give me the correct IP address so I'm not sure what's happening here. I know it's not my computer since it's happening on all devices on my network.
Here's my RouterOS config:
[admin@MikroTik] > export
# apr/25/2023 11:57:13 by RouterOS 6.48
# software id = 208M-3ZFP
# model = RBD52G-5HacD2HnD
# serial number = CDFD0D8FE730
add admin-mac=08:55:31:22:60:9B auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=Redacted station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    country=australia disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=Redacted station-roaming=enabled \
add disabled=no keepalive-frames=disabled mac-address=0A:55:31:22:60:9F \
    master-interface=wlan1 multicast-buffering=disabled name=wlan3 ssid=\
    "redacted" wds-cost-range=0 wds-default-cost=0 wps-mode=\
    disabled
add disabled=no keepalive-frames=disabled mac-address=0A:55:31:22:60:A0 \
    master-interface=wlan1 multicast-buffering=disabled name=wlan4 ssid=\
    "redacted" wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=redacted \
    wpa2-pre-shared-key=redacted
add name=dhcp ranges=10.0.0.20-10.0.0.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
    ord,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=wlan2
add address=10.0.0.1/24 comment=defconf interface=bridge network=10.0.0.0
add address=10.0.0.25/8 comment="NUC IP address" interface=bridge network=\
    10.0.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=10.0.0.25 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=443 in-interface=all-ethernet \
    protocol=tcp to-addresses=10.0.0.25 to-ports=443
add action=dst-nat chain=dstnat dst-port=22 in-interface-list=WAN protocol=tcp \
    to-addresses=10.0.0.25 to-ports=22
add action=dst-nat chain=dstnat dst-port=5269 in-interface-list=WAN protocol=\
    tcp to-addresses=10.0.0.25 to-ports=5269
add action=dst-nat chain=dstnat dst-port=25 in-interface-list=WAN protocol=tcp \
    src-port="" to-addresses=10.0.0.25 to-ports=25
add action=dst-nat chain=dstnat dst-port=587 in-interface-list=WAN protocol=tcp \
    to-addresses=10.0.0.25 to-ports=587
add action=dst-nat chain=dstnat dst-port=993 in-interface-list=WAN protocol=tcp \
    to-addresses=10.0.0.25 to-ports=993
add action=dst-nat chain=dstnat dst-port=80 protocol=tcp to-addresses=10.0.0.25 \
    to-ports=80
/system clock
set time-zone-name=Australia/Melbourne
/tool graphing interface
add store-on-disk=no
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
BetaQuasi
Re: HTTP websites are returning RouterOS
Tue Apr 25, 2023 6:23 pm
Your NUC’s IP is 10.0.0.25? You’ve assigned that IP (as a /8?) to your bridge on the router…. remove that to start. Also your last dstnat rule for port 80 doesn’t define an incoming interface.
k6ccc
Tue Apr 25, 2023 7:08 pm
You have a NAT for several ports to 10.0.0.25 - which I presume is your server. You do not however have a NAT for port 80. Therefore port 80 traffic is going to the router itself.
Add this (although you may really only want this to be from the WAN and not all-ethernet - else ALL port 80 traffic will be redirected to your server (including outbound) - same with your port 443 rule that I copied this from)
add action=dst-nat chain=dstnat dst-port=80 in-interface=all-ethernet \
    protocol=tcp to-addresses=10.0.0.25 to-ports=80
mkx
Tue Apr 25, 2023 8:19 pm
These two NAT rules are wrong:
add action=dst-nat chain=dstnat dst-port=443 in-interface=all-ethernet in-interface-list=WAN \
add action=dst-nat chain=dstnat dst-port=80 in-interface-list=WAN \
rextended
Tue Apr 25, 2023 9:23 pm
Is not provided any relevant info to the final scope.
Paste this on terminal for fix all the errors, (or at least make all firewall errors omogeneous ;) )...
Do not forget the { }
fix code
set bridge protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n station-roaming=disabled
set [ find default-name=wlan2 ] station-roaming=disabled
set wlan3 keepalive-frames=enabled multicast-buffering=enabled wds-cost-range=50-150 wds-default-cost=100
set wlan4 keepalive-frames=enabled multicast-buffering=enabled wds-cost-range=50-150 wds-default-cost=100
set [find where dst-port="443"] !in-interface in-interface-list=WAN !to-ports
set [find where dst-port="22"] !to-ports
set [find where dst-port="5269"] !to-ports
set [find where dst-port="25"] !src-port !to-ports
set [find where dst-port="587"] !to-ports
set [find where dst-port="993"] !to-ports
set [find where dst-port="80"] in-interface-list=WAN !to-ports
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,!dude,tikapp"
snowl
Wed Apr 26, 2023 3:44 am
Thanks all, solved! Really appreciate it :)
celinedion
Fri Jun 02, 2023 11:59 am
Access your router's administration interface and review the settings related to DNS and URL filtering. Look for any settings that might be redirecting or blocking HTTP traffic.mapquest driving directions
Users browsing this forum: lurker888 and 116 guests
