mobilexpi
RouterOS 7.8 - How to see how many routes are received by a BGP peer?
Tue Apr 25, 2023 8:37 pm
Hi guys,
I hope you're doing well. I have upgraded some dozens of CCRs from v6 to v7, they are running fine, but it looks like the prefix count information has been lost (or it changed location).
DarkNate
Re: RouterOS 7.8 - How to see how many routes are received by a BGP peer?
Tue Apr 25, 2023 10:04 pm
Prefix count is dead on ROS v7.8 at least. You cannot verify how many routes a peer sent to you, but you can check how many routes you sent to a remote peer via /routing bgp ad print
mobilexpi
Tue Apr 25, 2023 10:10 pm
Anyone from Mikrotik support team?
Best regards,
mobilexpi
Tue Apr 25, 2023 10:11 pm
Thank you @DarkNate, I hope Mikrotik solves this bug soon
mrz
Tue Apr 25, 2023 11:13 pm
received routes can be seen in /routing route menu, with appropriate params and count-only you can see the number.
mobilexpi
Wed Apr 26, 2023 8:53 am
What would be the appropriate parameter? I would like to see all the prefixes being received from the IXP interface, they share the same BGP session (since it points to the route servers), but gateway addresses are different for certain prefixes.
Best regards
mrz
Wed Apr 26, 2023 8:58 am
Just look at available parameters, bgp.peer-cache-id or belongs-to is the easiest to get all routes from the peer.
rextended
Wed Apr 26, 2023 12:42 pm
Best regards
v7 only code
/routing
:foreach item in=[bgp session find] do={
    :local rnam "unknown"
    :local radd [bgp session get $item remote.address]
    :local prfix "32"
    :if ([:typeof $radd] = "ip6") do={:set prfix "128"}
    :local srch [bgp connection find where remote.address="$radd/$prfix"]
    :if ([:len $srch] = 1) do={:set rnam [bgp connection get $srch name]}
    :local cnt4 [:len [route find where belongs-to="bgp-IP-$radd"]]
    :local cnt6 [:len [route find where belongs-to="bgp-IP6-$radd"]]
    :put "BGP $radd ($rnam) IPv4 $cnt4 IPv6 $cnt6"
CharlieB
Tue May 30, 2023 11:42 pm
I suppose the number is available from SNMP? because I doubt you can run through ~4M routes every 5 minutes, for every peer, by script, without performance impact.
CharlieB
Sat Jun 10, 2023 6:56 pm
To expand on my former question, in the past 25 or so years I have been using SNMP monitoring on the number of routes received from peers in order to update prefix limits before they are hit, particularly on IXPs, and generate alarms from NMSs when upper and lower threshold were broken. This is a functionality every device I dealt with before Mikrotik has offered in the same time frame (Cisco, Juniper, Enterasys, Extreme, Foundry, Brocade), and to my understanding, that also existed in previous Mikrotik software versions.
CharlieB
Sat Jun 10, 2023 6:58 pm
v7 only code
/routing
    :local prfix "32"
For which version in V7 is this? It produces all peers with 0 as output for me on 7.9 (maybe because all my BGP sessions are in a separate VRF to isolate Control- and Data plane?)
Cha0s
Sun Jun 11, 2023 9:39 pm
BGP stats over SNMP was never available on MikroTik.
We just got some SNMP support in 7.10rc.
scotth
Thu Oct 12, 2023 4:26 am
This gives me the information on IPv4 I've sent to peers, but doesn't seem to show IPv6 sent to peers. Either that or I'm not sending any routes to my IPv6 peers. I was just recently assigned an ASN, IPv4, and IPv6 from ARIN and I'm attempting to make sure I have it configured correctly. Is this supposed to show them all?
This is what I'm getting:
0 peer=bgp-securebit-ipv4-1 dst=23.163.120.0 afi=ip
nexthop=85.202.203.130 origin=0 as-path=sequence 11913
0 peer=bgp-route64-ipv4-1 dst=23.163.120.0 afi=ip
nexthop=100.64.111.186 origin=0 as-path=sequence 11913
[Update].
I got it working. The key was to add a static blackholed route to my /44 and then bam it worked.
Users browsing this forum: loloski and 64 guests
