I'm learning the new ROS 7 / WiFi Wave2 and CAPsMAN on 3011 (MAN) and hAP ax2 (CAP).
I set up everything and I have running radio, but clients on CAP can't get IP.
I additionally setup Datapath, and I read on forum to try add cap-wifi1 to bridge but these doesn't do the trick.
What I missed?
Thank You
Code: Select all
add name=DEFAULT-BRIDGE
/interface wifiwave2
add configuration.mode=ap name=cap-wifi1
/interface pppoe-client
add add-default-route=yes dial-on-demand=yes disabled=no interface=ether1 \
name=ISP use-peer-dns=yes user=username
/interface wifiwave2 channel
add disabled=no frequency=2300-7000 name=5GHZ width=20/40/80mhz
/interface wifiwave2 datapath
add bridge=DEFAULT-BRIDGE disabled=no interface-list=all name=datapath1
/interface wifiwave2 security
add authentication-types=wpa3-psk disabled=no name=WPA3 wps=disable
/interface wifiwave2 configuration
add channel=5GHZ country=Hungary datapath=datapath1 disabled=no name=\
"MAIN CFG" security=WPA3 ssid=WIFINAME
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool0 interface=DEFAULT-BRIDGE name=dhcp1
/port
set 0 name=serial0
add bridge=DEFAULT-BRIDGE interface=sfp1
add bridge=DEFAULT-BRIDGE interface=ether2
add bridge=DEFAULT-BRIDGE interface=ether3
add bridge=DEFAULT-BRIDGE interface=ether4
add bridge=DEFAULT-BRIDGE interface=ether5
add bridge=DEFAULT-BRIDGE interface=ether6
add bridge=DEFAULT-BRIDGE interface=ether7
add bridge=DEFAULT-BRIDGE interface=ether8
add bridge=DEFAULT-BRIDGE interface=ether9
add bridge=DEFAULT-BRIDGE interface=ether10
add bridge=DEFAULT-BRIDGE interface=cap-wifi1
add bridge=DEFAULT-BRIDGE interface=cap-wifi2
/interface wifiwave2 capsman
set ca-certificate=auto enabled=yes package-path="" require-peer-certificate=\
no upgrade-policy=none
/interface wifiwave2 provisioning
add action=create-dynamic-enabled disabled=no master-configuration="MAIN CFG" \
supported-bands=5ghz-ax
add address=192.168.1.1/24 interface=sfp1 network=192.168.1.0
/ip cloud
set ddns-enabled=yes
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes
add action=masquerade chain=srcnat out-interface=ISP
/system clock
set time-zone-name=Europe/Budapest
