Kernal87
LoadBalancing over 2 Wireguard Interfaces
Wed Apr 26, 2023 1:55 am
First of all hello together.
I am planning to implement a bit more complex network design.
I am currently routing public IPs to side A and routing them through a wireguard tunnel over the internet to side B. This works without any problems.
But now the internet connection on side B is not really good and I add a second ISP and want to route the traffic through two tunnels. The return path should also run through the two tunnels again.
The private clients from 192.168.8.0/24 should be routed to the outside via both ISPs.
I don't know exactly how to do the load balancing ?
Can I just make two static routes (1. 10.99.255.194, 2. 10.99.255.198) with the same distance for 46.XX.XX.240/28?
Here is a sketch ( I am not a Picasso) :) :
Thank you very much for your support.
Users browsing this forum: No registered users and 51 guests
