PiniuBudyniu
Hardware compatible with 10 inch rack
Thu Apr 27, 2023 2:04 am
Can someone tell me, if there is a way to find out, which MikroTik devices are compatible with 10 inch rack cabinet? Just bought new house and have no space left for 19 inch (didn't think about it) and my wife says a big NO to devices being left in open space, so I have to improvise. What I need is a router and some switches. Don't want to use shelves though, so I'm looking for devices mounted directly.
Thanks for reading.
Ca6ko
Long time Member
Long time Member
Re: Hardware compatible with 10 inch rack
Thu Apr 27, 2023 9:28 am
Although the name Mikrotik is from the Latvian micro net, in their line of equipment they completely bypass the small 10" racks. So you have to either use shelves or make the mounts yourself.
mkx
Thu Apr 27, 2023 11:27 am
Thrre's a line if 200mm wide devices (check this forum thread: viewtopic.php?t=176757). It seems (unfortunately) that this line includes only switches, but no routers.
And MT has a part which is supposed to help mounting those 200mm devices in a 10" rack: https://mikrotik.com/product/rmk2_10
Users browsing this forum: ulds and 111 guests
