mitzone
MYNETNAME.NET is down. IP Cloud DDNS not working.
Thu Apr 27, 2023 1:01 pm
Looks like MYNETNAME.NET is down. IP Cloud DDNS not working.
Can you take a look?
OriginalHutch
Re: MYNETNAME.NET is down. IP Cloud DDNS not working.
Thu Apr 27, 2023 1:03 pm
I was having the same issue but it looks like it's back up now.
wispmikrotik
Thu Apr 27, 2023 1:06 pm
The same here.
vasilaos
Thu Apr 27, 2023 1:07 pm
same problem here
mitzone
Thu Apr 27, 2023 1:12 pm
yes, back up now. Lasted about 1 hour.
vasilaos
Thu Apr 27, 2023 1:20 pm
yes it was back up and its down again now
OriginalHutch
Thu Apr 27, 2023 1:25 pm
Yep same here. Just got an alert.
T1000
Thu Apr 27, 2023 1:39 pm
Same here... Whats going on?
Lenry
Thu Apr 27, 2023 1:45 pm
same for me :(
buvarbeno
Thu Apr 27, 2023 1:47 pm
Ditto, same problem here, I cannot reach my home VPN and cloud domain name is not resolvable.
Mi folyik itt Gyöngyösön?!
woland
Thu Apr 27, 2023 2:23 pm
Hát a Gyöngyös-patak!
vitovanjak
Thu Apr 27, 2023 4:57 pm
Seems to be stable now
Larsa
Thu Apr 27, 2023 8:50 pm
At least for now.
Unfortunately, this was not an isolated incident as the MT cloud appears to lack sufficient redundancy. Whenever possible, we are phasing out the built-in function in favour of Cloudflare DDNS which is highly redundant and locally available through out the world.
k6ccc
Fri Apr 28, 2023 2:32 am
I also have never used the Mikrotik DDNS service. Using Dynu.com and have never had a failure in a good five years.
anav
Fri Apr 28, 2023 8:25 pm
At least for now.
Naturally, it works, and thus why MT should provide Cloudflare ZeroTrust Tunnel! Reliable!, safe! an excellent options package for all routers.
Larsa
Fri Apr 28, 2023 9:39 pm
gogotha
Wed Dec 11, 2024 12:34 am
noticed I dropped a few ddns routers, is it down? I have been pushing the router alone for the ddns service and will need to stop if the service is getting terminated.
infabo
Wed Dec 11, 2024 1:24 am
thanks for necroposting. better continue here: viewtopic.php?t=213191
