AlexM2020
PPPoE Server Mikrotik With LTU Device
Fri Apr 28, 2023 10:51 am
Good morning,
I'm looking for help on the forum for a small problem that I can not solve.
I have a PPPoE server configured with Mikrotik which works fine with all Ubiquity devices, PPPoE connects and everything works.
I tested a LTU Base Station, with the latest firmware update.
From here I started having these messages on the Mikrotik Log however the PPPoE connects even if with bad Troughput.
Example:
pppoe, ppp, info <pppoe-xxxx>: terminating...
pppoe, ppp, info, account xxxx logged out
pppoe, ppp, info <pppoe-xxxx>: disconnected
pppoe, info PPPoE connection established from
pppoe, ppp, info, account xxxx logged in
pppoe, ppp, info <pppoe-xxxx>: authenticated
pppoe, ppp, info <pppoe-xxxx>: connected
pppoe, ppp, info <pppoe-xxxx>: using encoding - MPPE128 statefull/MPPE128 stateless
pppoe, ppp, info xxxx: CCP lost compression got out of sync: disabling compression
ppp, error, critical xxxx: Encryption got out of sync - disabling
Does anyone have any suggestions?
Users browsing this forum: DanMos79, dsfak, Google [Bot], jmszuch1, Qanon, Ramirocuei, tnperron, UkRainUa and 183 guests
