Sun May 21, 2023 2:24 am
Disagree with JV, the clue here he is a well trained person knowing what he is doing, and giving such flippant advice to a beginner is both dangerous and foolish.
The only method you should consider connecting to your router for the purposes of accessing LAN resources or more likely to be able to config the router is through VPN and wireguard is part of RoS and fairly easier compared to other VPN methods. Highly recommended.
Another common method to access servers on your LAN is port forwarding and here ensure
a. the server is password protected 2 factor best
b. you limit users by source address
instead of port forwarding.
......... if it all possible use ZeroTrust Cloudflare tunnel in a container ( sadly although highly needed, MT has elected not to make this available as part of OS like wireguard, but not even an options package, shame on them ).
