tspascoal
What is the equivalent of a CAP for the outside?
Sat Apr 29, 2023 4:50 pm
Which models are appropriate to use as an outdoor access point?
Basically what is the equivalent of a CAP but weather proof?
Thank you
anav
Re: What is the equivalent of a CAP for the outside?
Sat Apr 29, 2023 7:02 pm
Have you looked at the Mikrotik hardware page, check out wireless systems........ assuming you want omni area coverage and not point to point right....
Lots of options...........have a look
holvoetn
Sat Apr 29, 2023 8:29 pm
Adding...
Start with wap :lol:
tty1
Sun Apr 30, 2023 4:42 pm
wAP series might be a good choice, entry-level cost and waterproof. But its airtightness is not good as Aruba's outdoor access point. You can also buy a plastic box, put the ap inside and seal it.
tspascoal
Fri May 05, 2023 2:04 pm
I was looking.... But in the wrong place. :)
I was looking in the Wireless Systems therefore my confusion. Wasn't expecting it to be in Wireless from home and office
tspascoal
Fri May 05, 2023 2:05 pm
Adding...
Thanks, that was it.
I was looking in the Wireless Systems therefore my confusion. Wasn't expecting it to be in Wireless from home and office :)
tspascoal
Fri May 05, 2023 2:07 pm
Thank you. Any suggestion on the box?
When you say put in a plastic box, do you mean as is or remove it from the out of the box case?
tty1
Fri May 05, 2023 2:11 pm
I mean put the ap inside of a waterproof plastic box you made (or purchased on amazon).
tspascoal
Wed May 24, 2023 8:46 pm
Yes, I understood that. but "you made" worries me. :)
There are probably high chances I will fry it, by doing something that will overheat it, since there is going to be sun involved :)
Therefore if you have some recommendaiton (from amazon for example)
holvoetn
Wed May 24, 2023 8:52 pm
I wouldn't worry too much about the case of wap.
I had sxt lte hanging outside for years in France.
Never a single drop inside.
Mikrotik is known for their outside equipment.
They know what it takes to keep it working.
Users browsing this forum: gabeluci, unhuzpt, zalciukaz and 109 guests
