zhup
Bandwidth test: microtik router vs lan host
Sat Apr 29, 2023 5:49 pm
My internet speed is 1000 Mb/s / 100 Mb/s and I can achieve this by doing the test directly from the router.
However, when I do the speed test from inside the LAN, no matter what speed test site I use, I don't manage to achieve similar speeds.
The PC on which I am doing the speed test has maximum queuing limits (1000 Mb/s / 1000 Mb/s), so queuing limits should not be a problem.
What could be the problem?
Thank you in advance.
Znevna
Re: Bandwidth test: microtik router vs lan host
Sat Apr 29, 2023 6:54 pm
What router are we talking about?
zhup
Sat Apr 29, 2023 7:36 pm
Mikrotik on PC.
holvoetn
Sat Apr 29, 2023 8:24 pm
Same question as Znevna...
How is cpu on router when doing test ?
Queue can be very resource intensive.
zhup
Sat Apr 29, 2023 8:37 pm
avg. 15%, max. 20%
It is an old i5 cpu, but it should not be resources problem.
holvoetn
Sat Apr 29, 2023 8:43 pm
Use tool profile / all.
If one of the cores is maxing out, you're at the limit.
Queue is using 1 core only, I understood.
zhup
Sat Apr 29, 2023 9:31 pm
max. 2%
holvoetn
Sat Apr 29, 2023 9:35 pm
Max 2% and before you said it was hovering at 15-20% during test ?
Then one of the cores had to be way higher.
Or does your cpu have 50 cores ? I don't think so...
I doubt that answer is correct.
zhup
Sat Apr 29, 2023 10:09 pm
Please see below screenshots:
holvoetn
Sat Apr 29, 2023 10:36 pm
That's not 2.. that's 26.
zhup
Sat Apr 29, 2023 11:19 pm
What are your suggestions?
nichky
Sun Apr 30, 2023 2:03 am
Did u try maybe traffic generator?
Ca6ko
Long time Member
Long time Member
Mon May 01, 2023 3:48 pm
Draw a diagram of the network we are testing. Specify the devices and where the traffic is coming from.
Looks like the maximum speed for wifi
PS Mikrotik has a "btest" program for the computer
zhup
Tue May 02, 2023 12:34 pm
I tested LAN with internal btest.
Summary:
Mikrotik to Internet (WAN) = Bandwidth OK
Mikrotik to PC (LAN) = Bandwidth OK
PC to Internet = Bandwidth not OK (download only 150-250 Mbps - even if I turn off all queues).
Any suggestions?
Ca6ko
Long time Member
Long time Member
Wed May 03, 2023 9:27 am
To be completely sure that the problem is in the ROS configuration, do a UDP test from the computer and router to the public server bandwidth-test
viewtopic.php?t=104266
zhup
Wed May 03, 2023 1:56 pm
Hello Ca6ko,
I did the bandwidth-test, but without result - see attachment.
I do not know if my settings are OK.
Now I need to wait 27h to repeat the test.
rextended
Wed May 03, 2023 2:18 pm
Any suggestions?
@zhup
[ color=#FFFFFF].[/color ]
Why you continue uselessly to add white dot on forum?
You want replace it later with spam link?
Stop that behaviour.
zhup
Wed May 03, 2023 2:25 pm
Any suggestions?
@zhup
Hello rextended,
Sorry for the confusion.
I just wanted the text to be more readable as line breaks are ignored.
mkx
Wed May 03, 2023 5:34 pm
They are not ... not entirely. You have to leave 2 empty lines after any text block (code, quote, list, etc.) to see one empty line. If one text block follows another, then I don't think this trick works (and yours with white dot does).
Multiple empty lines are honoured as well.
Users browsing this forum: complexxL9, GoogleOther [Bot], VMX and 68 guests
